I am using a xavier Orin module and during the power cycle, we see the following error randomly.:
It can not read information from QSPI and has to power cycle sometime to boot up again.
Hi, Kevin.
The evaluation board from nvidia has a power button controlled by the MCU and it never failed.
Out customer designed board does not have a control circuit as Nvidia and it is hard turn on/off both 12V and 5V.
The failure will happen much often if i turn back the power short after I turn off the power. but if I wait 15 seconds or more to turn the unit after i turn off, the system will not fail.
Here is my questions:
What is the minimum time delay required for the +5VDC up after +12VDC turn?
Is there a minimum time required for the down before we can turn it back?
Please let me know if you understand my questions.
Best REgards
Jie Zhou
Smith & Nephew
Hi, it looks like discharging issue. Please check the power off sequence and compare to that of Design Guide or devkit. You may need to add/modify discharge circuit. You can refer to the DG for detail of that.
