Hi All,
I’m working on JetPack4.4, L4T32.4.3
I want to use V4L2 capture RAW14 image
According to this post to modify
only different is vi4_formats.h for TX2, and I modify vi5_formats.h for AGX Xavier
But it still doesn’t work…
Have any ideas?
Hi All,
Have any ideas?
What’s your status? Driver probe without problem?
Yes. Because I removed i2c.
When I set V4L2_PIX_FMT_SRGGB12 , it can work.
Get the trace log for the RAW14 case to check.
Hi ShaneCCC,
I’m trying another way to check RAW14 can work or not.
By this command:
v4l2-ctl -d /dev/video0 --set-fmt-video=width=2592,height=1944,pixelformat=RG14 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test14.raw
And it work well!
Then I use c code to to same thing, it will got
And Then check /include/uapi/linux/videodev2.h had added V4L2_PIX_FMT_SRGGB14
How can I do next?
Suppose it could be the /include/uapi/linux/videodev2.h didn’t include in your code.
