Can the Xavier support the following encoding and decoding resolution - 2560x1024@30?
Hi @igal.kroyter ,
You can find the detailed informaitons about encoding and decoding.
@ ozguryildiz, thanks for your prompt reply. But my question was specifically for the abovementioned resolution.
IOW, could there be any problem with CSI or eDP to input and output the requested 2560x1024@30 resolution?
It should work in CSI frame capture if you program sensor dirver/device tree properly. In display output, ideally it should work but default we try with standard resolutions such as 1920x1080, 3840x2160. 2560x1024@30 is not practically verified.
