Hello, I would like to make the “rear” (J513) USB3.1C port an OTG port instead of a HOST-only port.
I have looked at the Adaptation Guide and I have made the following modifications. See below.
To summarize,
- Under xusb_padctl@3520000/ports/usb2-0, I changed the mode to "host"
- Under xusb_padctl@3520000/ports/usb2-1, I changed the mode to "otg"
- Under xudc@3550000, I changed phys to <0xd8 0xdb>, which are the handles corresponding to usb2-1 and usb3-0, respectively
- Under xudc@3550000, I changed phy-names to
- Under usb_cd, I changed phys to <0xd8> (i.e. usb2-1) -- This node does not appear in the Adaptation Guide, but I changed it anyway. I see no difference whether it is set to usb2-0 or usb2-1.
It seems to work partially: the “front” J512 port (usb2-0, usb3-2) no longer acts as a USB device when I plug it in, and the J513’s port (usb2-1, usb3-0) device tree appears to have the OTG characteristics: /proc/device-tree/xudc@3550000/phys and phy names seem to be correct.
However, when I connect the port to my PC, it does not detect a device. I’m wondering if I need to do more. I noticed the scripts under “/opt/nvidia/nv-l4t-usb-device-mode” - do I have to configure something to trigger these services/scripts?
Any suggestions regarding what I might be missing?
Device tree changes below:
xusb_padctl@3520000 {
compatible = "nvidia,tegra19x-xusb-padctl";
reg = <0x0 0x3520000 0x0 0x1000 0x0 0x3540000 0x0 0x1000>;
reg-names = "padctl", "ao";
interrupts = <0x0 0xa7 0x4>;
resets = <0x5 0x72>;
reset-names = "padctl";
status = "okay";
pex_dvdd-supply = <0x76>;
pex_hvdd-supply = <0x77>;
pex_pll_hvdd-supply = <0x77>;
vclamp_usb-supply = <0xa>;
avdd_usb-supply = <0xd3>;
avdd_pll_nvhs_eutmip-supply = <0x77>;
linux,phandle = <0xd5>;
phandle = <0xd5>;
pads {
usb2 {
clocks = <0x4 0xa5>;
clock-names = "trk";
lanes {
usb2-0 {
status = "okay";
#phy-cells = <0x0>;
nvidia,function = "xusb";
linux,phandle = <0xd6>;
phandle = <0xd6>;
usb2-1 {
status = "okay";
#phy-cells = <0x0>;
linux,phandle = <0xd8>;
phandle = <0xd8>;
usb2-2 {
status = "okay";
#phy-cells = <0x0>;
linux,phandle = <0xda>;
phandle = <0xda>;
usb2-3 {
status = "okay";
#phy-cells = <0x0>;
linux,phandle = <0xd9>;
phandle = <0xd9>;
usb3 {
lanes {
usb3-0 {
status = "okay";
#phy-cells = <0x0>;
linux,phandle = <0xdb>;
phandle = <0xdb>;
usb3-1 {
status = "disabled";
#phy-cells = <0x0>;
usb3-2 {
status = "okay";
#phy-cells = <0x0>;
linux,phandle = <0xd7>;
phandle = <0xd7>;
usb3-3 {
status = "okay";
#phy-cells = <0x0>;
linux,phandle = <0xdc>;
phandle = <0xdc>;
ports {
usb2-0 {
status = "okay";
vbus-supply = <0x1c>;
[b] mode = "host";
[/b] };
usb2-1 {
status = "okay";
[b] mode = "otg";
[/b] };
usb2-2 {
status = "okay";
mode = "host";
usb2-3 {
status = "okay";
vbus-supply = <0xd4>;
mode = "host";
usb3-0 {
status = "okay";
nvidia,usb2-companion = <0x1>;
usb3-1 {
usb3-2 {
status = "okay";
nvidia,usb2-companion = <0x0>;
usb3-3 {
status = "okay";
nvidia,usb2-companion = <0x3>;
nvidia,usb3-gen1-only = <0x1>;
prod-settings {
#prod-cells = <0x4>;
prod_c_bias {
prod = <0x0 0x284 0x38 0x38>;
prod {
prod = <0x0 0x24 0xfff 0x0>;
usb_cd {
compatible = "nvidia,tegra194-usb-cd";
nvidia,xusb-padctl = <0xd5>;
[b] phys = <0xd6>;
[/b]
phy-names = "otg-phy";
status = "okay";
linux,phandle = <0x178>;
phandle = <0x178>;
xudc@3550000 {
compatible = "nvidia,tegra194-xudc";
reg = <0x0 0x3550000 0x0 0x8000 0x0 0x3558000 0x0 0x1000>;
interrupts = <0x0 0xa6 0x4>;
clocks = <0x4 0x109 0x4 0x115 0x4 0x113 0x4 0x110>;
iommus = <0x2 0x1c>;
dma-coherent;
status = "okay";
avdd-usb-supply = <0xd3>;
extcon-cables = <0x79 0x0>;
extcon-cable-names = "vbus";
#extcon-cells = <0x1>;
[b] phys = <0xd8 0xdb>;
phy-names = "usb2-1", "usb3-0";
[/b] nvidia,boost_cpu_freq = <0x4b0>;
linux,phandle = <0x179>;
phandle = <0x179>;
xhci@3610000 {
compatible = "nvidia,tegra194-xhci";
reg = <0x0 0x3610000 0x0 0x40000 0x0 0x3600000 0x0 0x10000>;
interrupts = <0x0 0xa3 0x4 0x0 0xa4 0x4 0x0 0xa7 0x4>;
interrupt-parent = <0x31>;
clocks = <0x4 0x10a 0x4 0x10b 0x4 0x10c 0x4 0x10d 0x4 0x10e 0x4 0x10f 0x4 0x110 0x4 0x111 0x4 0x113 0x4 0x115 0x4 0x67 0x4 0xe 0x4 0x64>;
clock-names = "xusb_hs_src", "xusb_host", "xusb_core_superspeed_clk", "xusb_falcon_src", "xusb_falcon_host_clk", "xusb_falcon_superspeed_clk", "xusb_fs_src", "xusb_fs_host_clk", "xusb_ss_src", "xusb_ss", "pll_u_480m", "clk_m", "pll_e";
iommus = <0x2 0x1b>;
dma-coherent;
status = "okay";
extcon-cables = <0x79 0x1>;
extcon-cable-names = "id";
phys = <0xd6 0xd8 0xd9 0xda 0xd7 0xdb 0xdc>;
phy-names = "usb2-0", "usb2-1", "usb2-3", "usb2-2", "usb3-2", "usb3-0", "usb3-3";
linux,phandle = <0x17a>;
phandle = <0x17a>;
