We open terminal command(lsusb -t )and check USB device can be working or not . When USB deivce fail state, the command was keep scan state (see fail.jpg). The issue alway haapen when reboot and plug in USB deviceon devkit and our carried board.
Bill
Hi Bill,
I understood that if lsusb is empty then it is failure case, but you didn’t reply my question.
If it always has problem after reboot, then under what case would it works?
Please help share the following information
A. Does the issue also happen on the other M.2 external SSD?
B.The test result of the following steps
- repro the issue
- plug the device to PC
- plug the device back to galen
Does the device get enumerated on PC after repro the issue?
Does the device get enumerated on galen after step 3
C. The detail repro steps, including
1.Peripherals :
2. Repo Steps :
3.Test result :
4. Expected behavior :
5. Other information :
D.The kernel log with debug logs enabled
1.Repro the issue
2. enable kernel debug logs
echo 'module usbcore +p' > /sys/kernel/debug/dynamic_debug/control
echo 'module xhci_hcd +p' > /sys/kernel/debug/dynamic_debug/control
echo 8 > /proc/sys/kernel/printk
- unplug and plug the device again (the device is supposed to be failed to enumerate)
dear Wayne.
→ we try to three NVMe SSD and same as issue
1.Peripherals :PChome線上購物 - is NVMe SSD
2. Repo Steps :
a. plug in NVMe SSD and check it’s working
b. lock USB SSD after reboot
c. check NVMe SSD and wasn’t find it
d. re-plug in SSD and was’t see the device
3.Test result : not working the NVMe SSD
Bill
control.zip (106 KB)
Do you mean 3 NVMe SSD which are all the same from this pchome link? Do you have other kind of NVMe SSD?
We were not asking you to share the content of “control”. I meant adding those line to the control node and then share the dmesg
If lsusb hangs, can you monitor “dmesg --follow” in another terminal (or preferably serial console) and see if anything shows up as you run “lsusb”?
dear Wayne.
we use the other two NVMe SSD and same as issue.
NVMe link:
PChome線上購物 -
TEKQ Taiwan Design
Ok, please share the log with the method in #23.
dear Wayne.
We save log.txt(NVM SSD can be working) and log1.txt(NVM SSD not working before reboot)
Hi Bill,
Please be more active on forum. It has been almost 3 weeks since your last update.
We will help check the log and may still need your input.
Bill,
Sorry for one more question. All the link you pasted here is just the nvme to usb adapter.
What is the nvme device you are using?
WayneWWW.
we try two NVM SSD .
1. https://24h.pchome.com.tw/prod/DRAH7H-A9009K4ZJ-->Intel NVM device
2. PChome 24h購物>WD NVM device
Hi bill,
Please try the patch here with Vid:Pid=152d:0583
[url]USB3 hangs when connecting a UASP enabled portable drive - Jetson TX2 - NVIDIA Developer Forums
WayneWWW.
ok, We will try this patch to test .
Bill
Does this issue get fixed?
WayneWWW.
Yes, we fix it this issue.
Bill
