Hi,guys
My Xavier’s fan never work. Some one can tell me how to turn it on?
Could you run sudo jetson_clocks and see if it runs?
BTW, are you using devkit?
you can sun the jetson_clocks:
sudo ~/jetson_clocks
or maybe:
sudo /usr/bin/jetson_clocks
Do beware that the fan normally only runs if the Xavier heats up, and it rarely heats up if not given a load. The “jetson_clocks” mentioned above sets clocks to max and turns on the fan rather than letting it auto adjust.
