Xavior NX codec support VP9 SVC (Scaled Video Coding)
I have a question for clearify about Jetson NX VP9 SVC ( Scaled Video Coding ) HW video decode and encode support capbliity , I check the datasheet . but there is not clearly metaion it support it or not
For Scalable Video Coding, we support it in H264 and H265. Please check the option in 01_video_encode:
        --svc                 Enable RPS Three Layer SVC [Default = disabled]
It is not supported for VP9.
Hi DaneLLL,
Is H264/H265 SVC supported in nvv4l2h264/265enc plug-in? I don’t see any related property setting with gst-inspect-1.0 nvv4l2h264enc.
It is supported in jetson_multimedia_api. Please refer to
/usr/src/jetson_multimedia_api/samples/01_video_encode
For running in the mode it would need to set the parameters frame by frame, so it is not easy to apply to gstreamer plugins. We suggest use jetson_multimedia_api. If you need the function in v4l2 plugins, we have gst-v4l2 open source and you may try to do customization.
