Xcb error occurs when launching isaacsim4.5 in ubuntu20.04
Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: NVIDIA GeForce RTX 4090
  • Driver Version: 535.230.02
Topic Description
Detailed Description
Installing isaacsim using pip method, error occurs when executing isaacsim command
Steps to Reproduce
  1. Update glibc to GLIBC 2.35
  2. conda create -n env_isaaclab python=3.10
  3. conda activate env_isaaclab
  4. pip install torch==2.5.1 torchvision==0.20.1 --index-url https://download.pytorch.org/whl/cu118
  5. pip install --upgrade pip
  6. pip install 'isaacsim[all,extscache]==4.5.0' --extra-index-url https://pypi.nvidia.com
  7. isaacsim
Error Messages
(lab2) ubuntu@ubuntu-4090:~/workspaces$ isaacsim
Loading user config located at: '/home/ubuntu/.local/share/ov/data/Kit/Isaac-Sim Full/4.5/user.config.json'
[Info] [carb] Logging to file: /home/ubuntu/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250618_180725.log
2025-06-18 10:07:25 [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn't available.
[0.034s] [ext: omni.kit.async_engine-0.0.1] startup
[0.124s] [ext: omni.metrics.core-0.0.1] startup
[0.124s] [ext: omni.client.lib-1.0.0] startup
[0.140s] [ext: omni.blobkey-1.1.2] startup
[0.140s] [ext: omni.stats-1.0.1] startup
[0.140s] [ext: omni.datastore-0.0.0] startup
[0.143s] [ext: omni.client-1.2.2] startup
[0.197s] [ext: omni.ujitso.default-1.0.0] startup
[0.201s] [ext: omni.hsscclient-1.1.1] startup
[0.208s] [ext: omni.gpu_foundation.shadercache.vulkan-1.0.0] startup
[0.212s] [ext: omni.assets.plugins-0.0.0] startup
[0.213s] [ext: omni.gpu_foundation-0.0.0] startup
[0.217s] [ext: carb.windowing.plugins-1.0.0] startup
[0.221s] [ext: omni.kit.renderer.init-0.0.0] startup
2025-06-18 10:07:26 [241ms] [Error] [omni.platforminfo.plugin] failed to find the package that core 24 belongs to.
2025-06-18 10:07:26 [241ms] [Error] [omni.platforminfo.plugin] failed to find the package that core 25 belongs to.
2025-06-18 10:07:26 [241ms] [Error] [omni.platforminfo.plugin] failed to find the package that core 26 belongs to.
2025-06-18 10:07:26 [241ms] [Error] [omni.platforminfo.plugin] failed to find the package that core 27 belongs to.
2025-06-18 10:07:26 [241ms] [Error] [omni.platforminfo.plugin] failed to find the package that core 28 belongs to.
2025-06-18 10:07:26 [241ms] [Error] [omni.platforminfo.plugin] failed to find the package that core 29 belongs to.
2025-06-18 10:07:26 [241ms] [Error] [omni.platforminfo.plugin] failed to find the package that core 30 belongs to.
2025-06-18 10:07:26 [241ms] [Error] [omni.platforminfo.plugin] failed to find the package that core 31 belongs to.
| Driver Version: 535.230.02    | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
| 0   | NVIDIA GeForce RTX 4090          | Yes: 0 |     | 24564   MB | 10de      | 0          |
|     |                                  |        |     |            | 2684      | 16760a40.. |
|     |                                  |        |     |            | 1         |            |
| OS: 20.04.6 LTS (Focal Fossa) ubuntu, Version: 20.04.6, Kernel: 5.15.0-139-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12013000 (1.20.13.0)
| Processor: Intel(R) Core(TM) i9-14900KF
| Cores: 24 | Logical Cores: 24
| Total Memory (MB): 64106 | Free Memory: 14177
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
[0.604s] [ext: omni.kit.pipapi-0.0.0] startup
[0.605s] [ext: omni.materialx.libs-1.0.6] startup
[0.609s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.609s] [ext: omni.usd.config-1.0.5] startup
[0.611s] [ext: omni.gpucompute.plugins-0.0.0] startup
[0.611s] [ext: omni.usd.libs-1.0.1] startup
[0.653s] [ext: omni.mdl-55.0.1] startup
[0.663s] [ext: omni.iray.libs-0.0.0] startup
[0.665s] [ext: omni.mdl.neuraylib-0.2.10] startup
[0.666s] [ext: omni.kit.usd.mdl-1.0.7] startup
[0.721s] [ext: omni.kit.telemetry-0.5.1] startup
[xcb] Unknown sequence number while appending request
[xcb] You called XInitThreads, this is not your fault
[xcb] Aborting, sorry about that.
[xcb] Extra reply data still left in queue
[xcb] This is most likely caused by a broken X extension library
Additional Information
What I’ve Tried
I tried using two computers with the same version but different GPUs, but I couldn’t install them either
Related Issues
@fan-ziqi have you also tried some of the suggestions by the mods in this thread regarding the Unknown sequence number while appending request error?
The problem was solved by replacing the conda source
conda config --add channels conda-forge
conda config --set channel_priority strict
