is frozen there. For this reason I can’t keep my system upgraded with the new code. I hope someone has the ability to help me to understand how to fix it. The commands that I have issued are the following :
# git clone https://github.com/OE4T/linux-tegra-4.9.git
# cd linux-tegra-4.9/
# git checkout oe4t-patches-l4t-r32.7 (but the same happens with 32.7.3)
# cp /proc/config.gz .
# gunzip config.gz
# mv config .config
# make menuconfig (KVM is already enabled)
# make -j4
# make -j4 modules_install
# make -j4 Image
# mv /boot/Image Image-kvm-old
# cp arch/arm64/boot/Image /boot/Image
# reboot
the dtb file to use is called : tegra210-p3448-0000-p3449-0000-a02.dtb and the extlinux.conf is something like this :
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
INITRD /boot/initrd
FDT /boot/tegra210-p3448-0000-p3449-0000-a02.dtb
APPEND ${cbootargs} quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
The messages which appear on the screen stay there forever :
This would change many things. The Nano is not compatible with Ubuntu 20.04. The kernel and other code is from 18.04 and it was never ported to 20.04 due to EOL.
I don’t see it as a duplicate,because I used a different JetPack version and a different set of patches and I also see a different output on the screen.
Im sure that the new Jetson Orin can run on a newer kernel and Jetpack version (that will not work with the Nano). And the same will happens with the board that will come after Orin. I know very well this kind of strategic and marketing attitude.
what kernel version are you running ? I’m tempted to upgrade to kernel 5.x ; did you enable kvm ? do you think it will work with ubuntu 22.04 ? I need it. I’m tempted to upgrade from 20.04 to 22.04.
Ah you are trying to use kernel 5.x
This won’t work as the kernel structure has subfolders outside of the kernel that you need to compile to get access to the GPU like access nvgpu and other porg stuff.
So you’re stuck to kernel 4.9 if you want the working binaries provided by nvidia.
The latest kernel and EOL from kernel.org is 4.9.337 although I am currently using 4.9.334
Actually I’m using 4.9.299+. I nice idea is to find the way to use 5.x ; I haven’t the abilities to do that,anyway. For me is anyway clear that nvidia wants to push us to buy the most expensive board orin and again the next board after orin and so on,in a forever loop. It seems they want to take us hostage, with the “blackmail” of the little security we are exposed if we don’t. Im sure that Orin will supports kernel 5 and more modern jetpacks. This is the nvidia marketing plan. They want to push us to buy new (expensive) hardware in a small amount of time (lets look how often do they churn out new workstation gpu’s,one every year !) if we want modern software,more security and more support,too.
Anyway,I read that the jetson nano will work with the kernel 5.x even if the nvidia drivers will not work. Anyway I haven’t understood how much it could be usable). So here the idea could be to install ubuntu 22.04 with the kernel 5.x as primary os and to use some kind of virtualization with the kernel 4.9 (ubuntu 18.04 with docker or qemu+kvm ?) to run the nvidia utilities.
