I’m trying to use the xform visual widget and looks like it’s not working as expected.
The extension loads correctly and I can see their properties in each xform object. However, when I click on “Display Local Axis” or I select a “Display Shape”, nothing is shown in the viewport. This happens with both xform objects and meshes.
I’m using Isaac Sim 2022.2.1. I also tried in Create 2022.3.3 with the same result. The extension version is 104.0.2 and I’m using Ubuntu 22.04.
