Xhci_hcd error
我在nx上使用了两个usb3.0接口,其中一个usb3.0是通过PCIE转的USB3.0,另外一个是nx自带的usb3.0,设备开机连接两个USB3.0能正常工作,工作4个小时后报以下错误:
Jun 19 21:02:47 test-desktop anacron[27323]: Anacron 2.3 started on 2024-06-19
Jun 19 21:02:47 test-desktop anacron[27323]: Normal exit (0 jobs run)
Jun 19 21:17:01 test-desktop CRON[29235]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Jun 19 22:00:16 test-desktop systemd[1]: Started Run anacron jobs.
Jun 19 22:00:16 test-desktop anacron[2692]: Anacron 2.3 started on 2024-06-19
Jun 19 22:00:16 test-desktop anacron[2692]: Normal exit (0 jobs run)
Jun 19 22:17:01 test-desktop CRON[4999]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Jun 19 22:32:43 test-desktop kernel: [15300.682495] xhci_hcd 0000:01:00.0: xHCI host not responding to stop endpoint command.
Jun 19 22:32:43 test-desktop kernel: [15300.691052] xhci_hcd 0000:01:00.0: Assuming host is dying, halting host.
Jun 19 22:32:43 test-desktop kernel: [15300.748660] xhci_hcd 0000:01:00.0: Host not halted after 16000 microseconds.
Jun 19 22:32:43 test-desktop kernel: [15300.756442] xhci_hcd 0000:01:00.0: Non-responsive xHCI host is not halting.
Jun 19 22:32:43 test-desktop kernel: [15300.764183] xhci_hcd 0000:01:00.0: Completing active URBs anyway.
Jun 19 22:32:43 test-desktop kernel: [15300.772300] xhci_hcd 0000:01:00.0: HC died; cleaning up
Jun 19 22:32:43 test-desktop kernel: [15300.773416] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.773460] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.773479] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.773506] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.773526] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.773543] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.773570] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.773588] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.773604] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.773628] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.773781] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.773808] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.773826] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.773851] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.773868] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.773885] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.773909] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.773926] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.773942] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.773967] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.774067] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.774085] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.774110] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.774128] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.774144] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.774168] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.774186] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.774203] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.774227] usb 4-2: usbfs: usb_submit_urb returned -108
Jun 19 22:32:43 test-desktop kernel: [15300.779551] xhci_hcd 0000:01:00.0: Stopped the command ring failed, maybe the host is dead
Jun 19 22:32:43 test-desktop kernel: [15300.788571] xhci_hcd 0000:01:00.0: Host not halted after 16000 microseconds.
Jun 19 22:32:43 test-desktop kernel: [15300.796363] xhci_hcd 0000:01:00.0: Abort command ring failed
Jun 19 22:32:43 test-desktop kernel: [15300.802815] tegra-pcie 10003000.pcie-controller: PCIE: Response decoding error, signature: 40100025
Jun 19 22:32:43 test-desktop kernel: [15300.812811] xhci_hcd 0000:01:00.0: HC died; cleaning up
Jun 19 22:32:43 test-desktop kernel: [15300.818903] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
Jun 19 22:32:43 test-desktop kernel: [15300.818921] tegra-pcie 10003000.pcie-controller: PCIE: Response decoding error, signature: 100100a9
Jun 19 22:32:43 test-desktop kernel: [15300.829067] tegra-pcie 10003000.pcie-controller: PCIE: Response decoding error, signature: 11010005
Jun 19 22:32:43 test-desktop kernel: [15300.839053] tegra-pcie 10003000.pcie-controller: PCIE: Response decoding error, signature: 11010009
Jun 19 22:32:43 test-desktop kernel: [15300.849070] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
Jun 19 22:32:43 test-desktop kernel: [15300.861795] pcieport 0000:00:01.0:   device [10de:10e5] error status/mask=00004000/00000000
Jun 19 22:32:43 test-desktop kernel: [15300.871164] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
Jun 19 22:32:43 test-desktop kernel: [15300.878925] pcieport 0000:00:01.0: broadcast error_detected message
Jun 19 22:32:43 test-desktop kernel: [15300.878929] pcieport 0000:00:01.0: AER: Device recovery failed
Jun 19 22:32:43 test-desktop kernel: [15300.878933] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0020
Jun 19 22:32:43 test-desktop kernel: [15300.878944] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
Jun 19 22:32:43 test-desktop kernel: [15300.891667] pcieport 0000:00:01.0:   device [10de:10e5] error status/mask=00004000/00000000
Jun 19 22:32:43 test-desktop kernel: [15300.901062] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
Jun 19 22:32:43 test-desktop kernel: [15300.908926] pcieport 0000:00:01.0: broadcast error_detected message
Jun 19 22:32:43 test-desktop kernel: [15300.908929] pcieport 0000:00:01.0: AER: Device recovery failed
Jun 19 22:32:43 test-desktop kernel: [15300.908941] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0020
Jun 19 22:32:43 test-desktop kernel: [15300.908952] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
Jun 19 22:32:43 test-desktop kernel: [15300.921764] pcieport 0000:00:01.0:   device [10de:10e5] error status/mask=00004000/00000000
Jun 19 22:32:43 test-desktop kernel: [15300.931204] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
Jun 19 22:32:43 test-desktop kernel: [15300.939083] pcieport 0000:00:01.0: broadcast error_detected message
Jun 19 22:32:43 test-desktop kernel: [15300.939085] pcieport 0000:00:01.0: AER: Device recovery failed
Jun 19 22:32:43 test-desktop kernel: [15300.939105] pcieport 0000:00:01.0: AER: Uncorrected (Non-Fatal) error received: id=0020
Jun 19 22:32:43 test-desktop kernel: [15300.939116] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
Jun 19 22:32:43 test-desktop kernel: [15300.951984] pcieport 0000:00:01.0:   device [10de:10e5] error status/mask=00004000/00000000
Jun 19 22:32:43 test-desktop kernel: [15300.961496] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
Jun 19 22:32:43 test-desktop kernel: [15300.969463] pcieport 0000:00:01.0: broadcast error_detected message
Jun 19 22:32:43 test-desktop kernel: [15300.969466] pcieport 0000:00:01.0: AER: Device recovery failed
Jun 19 22:32:43 test-desktop kernel: [15300.969469] pcieport 0000:00:01.0: AER: Multiple Uncorrected (Non-Fatal) error received: id=0020
Jun 19 22:32:43 test-desktop kernel: [15300.969486] tegra-pcie 10003000.pcie-controller: PCIE: Response decoding error, signature: 100100a9
Jun 19 22:32:43 test-desktop kernel: [15300.979665] tegra-pcie 10003000.pcie-controller: PCIE: Response decoding error, signature: 11010005
Jun 19 22:32:43 test-desktop kernel: [15300.989858] tegra-pcie 10003000.pcie-controller: PCIE: Response decoding error, signature: 11010009
Jun 19 22:32:43 test-desktop kernel: [15301.000028] pcieport 0000:00:01.0: PCIe Bus Error: severity=Uncorrected (Non-Fatal), type=Transaction Layer, id=0008(Requester ID)
Jun 19 22:32:43 test-desktop kernel: [15301.013015] pcieport 0000:00:01.0:   device [10de:10e5] error status/mask=00004000/00000000
Jun 19 22:32:43 test-desktop kernel: [15301.022561] pcieport 0000:00:01.0:    [14] Completion Timeout     (First)
Jun 19 22:32:43 test-desktop kernel: [15301.030545] pcieport 0000:00:01.0: broadcast error_detected message
Jun 19 22:32:43 test-desktop kernel: [15301.030548] pcieport 0000:00:01.0: AER: Device recovery failed
Jun 19 22:32:43 test-desktop kernel: [15301.030557] usb 4-2: USB disconnect, device number 2
Jun 19 22:32:43 test-desktop kernel: [15301.031056] tegra-pcie 10003000.pcie-controller: PCIE: Response decoding error, signature: 40100025
Jun 19 23:04:52 test-desktop systemd[1]: Started Run anacron jobs.
Jun 19 23:04:52 test-desktop anacron[8303]: Anacron 2.3 started on 2024-06-19
Jun 19 23:04:52 test-desktop anacron[8303]: Normal exit (0 jobs run)
Jun 19 23:17:01 test-desktop CRON[8750]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Jun 20 00:02:33 test-desktop systemd[1]: Started Run anacron jobs.
Jun 20 00:02:33 test-desktop anacron[10425]: Anacron 2.3 started on 2024-06-20
Jun 20 00:02:33 test-desktop anacron[10425]: Will run job `cron.daily' in 5 min.
Jun 20 00:02:33 test-desktop anacron[10425]: Jobs will be executed sequentially
Jun 20 00:07:33 test-desktop anacron[10425]: Job `cron.daily' started
Jun 20 00:07:33 test-desktop anacron[10610]: Updated timestamp for job `cron.daily' to 2024-06-20
Jun 20 00:07:33 test-desktop cracklib: no dictionary update necessary.
Jun 20 00:07:34 test-desktop anacron[10425]: Job `cron.daily' terminated
Jun 20 00:07:34 test-desktop anacron[10425]: Normal exit (1 job run)
不清楚报这个问题的原因,请帮忙分析下,谢谢
If the issue is from the “sb3.0是通过PCIE转的USB3.0”, then it is not running NVIDIA driver, it could be from upstream driver issue.
