xmonad installed on jetson orin.
However, I put in the haskell program, xmonad, and logged in, but it fails with an error.
The error was in /var/log/Xorg.0.log.
Is this a incompatibility between jetson and xmonad?
less /var/log/Xorg.0.log
[ 798.457] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 798.457] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 798.457] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 798.457] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 798.457] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 798.457] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 798.457] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 798.457] (II) NVIDIA(0): Config Options in the README.
/etc/X11/xorg.conf
Section "Module"
Disable "dri"
SubSection "extmod"
Option "omit xfree86-dga"
EndSubSection
EndSection
Section "Device"
Identifier "Tegra0"
Driver "nvidia"
Option "ConnectToAcpid" "True"
Option "AcpidSocketPath" "/var/run/acpid.socket" // I added this option.
Option "AllowEmptyInitialConfiguration" "true" // I added this option.
EndSection
