Hi NV_Team,
We have two XNX devices working for several days, one XNX run software reboot then can’ t bring up and lsusb on PC seems XNX in recovery mode. We take the XNX SOM and plug on the XNX Devkit CVB still in recovery mode. Here is the uart log. Please help to check it.
UART Log :
I> rst_source : 0x0
[0000.062] I> rst_level : 0x0
[0000.065] I> Boot-device: QSPI
[0000.068] I> Qspi flash params source = brbct
[0000.072] I> Qspi using bpmp-dma
[0000.075] I> Qspi clock source : pllp
[0000.079] I> QSPI Flash Size = 32 MB
[0000.082] I> Qspi initialized successfully
[0000.086] I> Active Boot chain : 1
[0000.089] I> Boot-device: QSPI
[0000.092] I> Qspi flash params source = brbct
[0000.098] W> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0000.105] I> Temperature = 28000
[0000.108] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.113] W> Skipping boost for clk: BPMP_APB
[0000.117] W> Skipping boost for clk: AXI_CBB
[0000.121] W> Skipping boost for clk: AON_CPU_NIC
[0000.125] W> Skipping boost for clk: CAN1
[0000.129] W> Skipping boost for clk: CAN2
[0000.133] I> Boot-device: QSPI
[0000.136] I> Boot-device: QSPI
[0000.139] I> Qspi flash params source = mb1bct
[0000.143] I> Qspi using bpmp-dma
[0000.146] I> Qspi clock source : pllc_out0
[0000.150] I> Qspi reinitialized
[0000.152] I> Qspi flash params source = mb1bct
[0000.158] E> NONE: Invalid value MemBct dram size: 0MB for slot: 2.
[0000.164] E> Task 39 failed (err: 0x102)
[0000.167] E> Top caller module: NONE, error module: NONE, reason: 0x02, aux_info: 0x01
[0000.175] I> MB1(1.5.1.6-t194-41334769-1740dd39) BIT boot status dump :
0000000000011111111110111111111111111111000100000000000000000000000000000000000000000000000000000000000000000000000000000000000011011000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
[0000.205] I> Reset to recovery mode
