Hi
I have a machine that I just upgraded from Centos 6.4 to Centos 6.5. Prior to the upgrade, it would stau up for weeks. Since the upgrade, the Xdisplay locks at random times when in use. If no one is using the machine it will stay up for several days. When the display locks I can still ssh into it. I have run startx – -logverbose6 and generated a nvidia bug report after the display locks up which I will attach. Please advise what other information you need to troubleshoot this problem.
Regards,
Tom
Edit 1
I think I figured out the problem. When Xorg got updated during the upgrade from C6.4 to C6.5 the symlinks to the glx module got overwritten. Adding the following to /etc/X11/xorg.conf appears to have fixed the problem:
Section “Files”
ModulePath “/usr/lib64/xorg/modules/extensions/nvidia”
ModulePath “/usr/lib64/xorg/modules”
FontPath “/usr/share/fonts/default/Type1”
EndSection
The FontPath was already there. After a reboot things seem back to normal again.
I found a reference to this @ http://elrepo.org/bugs/view.php?id=425 in case anyone is interested.
nvidia-bug-report.log.gz (76.7 KB)
