I have users that have been reporting for some time that their workstations would unexpectedly log them out returning them to the gdm log in screen. I believe that it is related to a previously reported bug that Xorg is not handling animated cursors properly and something with the AnimCurNotifyTimer is causing the Xorg server to crash. I filed a support case with Red Hat saying as much. After some back and forth, RedHat directed me to contact NVidia because they do not have the means to debug the Nvidia drivers and as such cannot read the full backtrace of the Xorg crash.
The issue occurs semiregularly, but unable to be forcibly reproduced so far. The crash has occurred on multiple different set ups for displays, but all of them are running RHEL 7, KDE, multihead with each head set up as a separate X display (e.g. 3 heads: :0.0, :0.1, :0.2) with as many as 8 heads running across 2 NVS 510s.
Unfortunately I am not able to submit a full nvidia-bug-report.log.gz, as I have to sanitize anything I submit of any sensitive data before uploading it to help tickets. If there are specific outputs/logs that are needed I can likely get them sanitized and uploaded here (as I’ve done so far with my RedHat support case). Hopefully this is not a problem.
Thanks,
Nate Calonder
xorg_backtrace.txt (1.02 KB)
