I’m running an Nvidia TX2 and need the device to run headless. However, as I will be remoting onto the device I need to be able to adjust the resolution output so I have a usable screen. The output defaults to 600x480. I’ve managed to deal with this by using xrandr to adjust the resolution, but this is only a temporary fix. I need the system to default to a higher/usable resolution.
The most common solution I’ve found is modifying the xorg.conf file to trick the system that an hdmi is connected. The issue that I’m facing is that I don’t have a xorg.conf file. The x11 directory that it would be located was never generated.
I’ve found instructions for generating this file, https://askubuntu.com/questions/25746/etc-x11-xorg-conf-doesnt-exist but it fails to generate. I get.
List of video drivers
fbdev
modesetting
nvidia
No devices to configure. Configuration failed.
(EE) Server terminated with error(2). Closing log file
I’ve also tried to create the x11 directory and just insert a copy of sample .conf file in there with no success.
I’ve reflashed the tx2 twice and have had no success. Does anyone have any suggestions on what I should do?
Thank you for your time and help.
Michael
