When starting an Xorg session I get a segmentation fault.
Please check log
[ 2078.800] (II) NVIDIA(0): Adding implicit MetaMode: "DP-4: nvidia-auto-select { ViewPortIn = 640 x 480, ViewPortOut = 2133 x 1600 + 213 + 0 }"
[ 2078.800] (--) NVIDIA(0): DPI set to (191, 184); computed from "UseEdidDpi" X config
[ 2078.800] (--) NVIDIA(0): option
[ 2078.800] (WW) NVIDIA: Failed to bind sideband socket to
[ 2078.800] (WW) NVIDIA: '/var/run/nvidia-xdriver-681eef91' Permission denied
[ 2078.800] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 2078.800] (II) NVIDIA: access.
[ 2078.828] (II) NVIDIA(0): Setting mode "DFP-4:nvidia-auto-select,DFP-0:nvidia-auto-select"
[ 2079.777] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 2079.778] (==) NVIDIA(0): Backing store enabled
[ 2079.778] (==) NVIDIA(0): Silken mouse enabled
[ 2079.778] (**) NVIDIA(0): DPMS enabled
[ 2079.778] (II) Loading sub module "dri2"
[ 2079.778] (II) LoadModule: "dri2"
[ 2079.778] (II) Module "dri2" already built-in
[ 2079.778] (II) NVIDIA(0): [DRI2] Setup complete
[ 2079.778] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 2079.778] (II) Initializing extension Generic Event Extension
[ 2079.778] (II) Initializing extension SHAPE
[ 2079.778] (II) Initializing extension MIT-SHM
[ 2079.778] (II) Initializing extension XInputExtension
[ 2079.778] (II) Initializing extension XTEST
[ 2079.778] (II) Initializing extension BIG-REQUESTS
[ 2079.778] (II) Initializing extension SYNC
[ 2079.778] (II) Initializing extension XKEYBOARD
[ 2079.778] (II) Initializing extension XC-MISC
[ 2079.778] (II) Initializing extension SECURITY
[ 2079.778] (II) Initializing extension XFIXES
[ 2079.779] (II) Initializing extension RENDER
[ 2079.779] (II) Initializing extension RANDR
[ 2079.779] (II) Initializing extension COMPOSITE
[ 2079.779] (II) Initializing extension DAMAGE
[ 2079.779] (II) Initializing extension MIT-SCREEN-SAVER
[ 2079.779] (II) Initializing extension DOUBLE-BUFFER
[ 2079.779] (II) Initializing extension RECORD
[ 2079.779] (II) Initializing extension DPMS
[ 2079.779] (II) Initializing extension Present
[ 2079.779] (II) Initializing extension DRI3
[ 2079.779] (II) Initializing extension X-Resource
[ 2079.779] (II) Initializing extension XVideo
[ 2079.779] (II) Initializing extension XVideo-MotionCompensation
[ 2079.779] (II) Initializing extension GLX
[ 2079.779] (II) Indirect GLX disabled.
[ 2079.779] (II) GLX: Another vendor is already registered for screen 0
[ 2079.779] (II) Initializing extension XFree86-VidModeExtension
[ 2079.779] (II) Initializing extension XFree86-DGA
[ 2079.779] (II) Initializing extension XFree86-DRI
[ 2079.779] (II) Initializing extension DRI2
[ 2079.780] (II) Initializing extension NV-GLX
[ 2079.780] (II) Initializing extension NV-CONTROL
[ 2079.780] (II) Initializing extension XINERAMA
[ 2079.795] (EE)
[ 2079.795] (EE) Backtrace:
[ 2079.795] (EE) 0: /usr/lib/Xorg (xorg_backtrace+0x89) [0x5584d5eef099]
[ 2079.795] (EE) 1: /usr/lib/Xorg (0x5584d5d9f000+0x15aeb9) [0x5584d5ef9eb9]
[ 2079.795] (EE) 2: /usr/lib/libc.so.6 (0x7f23419a1000+0x42560) [0x7f23419e3560]
[ 2079.795] (EE) 3: /usr/lib/libc.so.6 (memcpy+0x23) [0x7f2341a5b213]
[ 2079.795] (EE) 4: /usr/lib/libnvidia-glcore.so.510.60.02 (0x7f233de00000+0xe64da4) [0x7f233ec64da4]
[ 2079.795] (EE) 5: /usr/lib/libnvidia-glcore.so.510.60.02 (0x7f233de00000+0x114a13a) [0x7f233ef4a13a]
[ 2079.795] (EE) 6: /usr/lib/libnvidia-glcore.so.510.60.02 (0x7f233de00000+0x114a1cd) [0x7f233ef4a1cd]
[ 2079.795] (EE) 7: /usr/lib/libnvidia-glcore.so.510.60.02 (0x7f233de00000+0xeb70a1) [0x7f233ecb70a1]
[ 2079.795] (EE) 8: /usr/lib/nvidia/xorg/libglxserver_nvidia.so (0x7f233c400000+0x8de46e) [0x7f233ccde46e]
[ 2079.795] (EE)
[ 2079.795] (EE) Segmentation fault at address 0x7f233cda9000
[ 2079.795] (EE)
Fatal server error:
[ 2079.795] (EE) Caught signal 11 (Segmentation fault). Server aborting
[ 2079.795] (EE)
[ 2079.795] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 2079.795] (EE) Please also check the log file at "/home/david/.local/share/xorg/Xorg.0.log" for additional information.
[ 2079.795] (EE)
[ 2080.773] (EE) Server terminated with error (1). Closing log file.
XOrg X Server 1.21.1.3
NVIDIA-SMI 510.60.02 Driver Version: 510.60.02 CUDA Version: 11.6
Arch Kernel: 5.17.3-arch1-1
