I have a standard FullHD monitor (LG 24MP55) connected via HDMI and GTX 1060.
$ xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
DVI-D-0 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 510mm x 290mm
1920x1080 60.00*+ 59.94 50.00 60.05 60.00 50.04
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1400x1050 59.98
1280x1024 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 60.00
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 59.94
640x480 59.94 59.93
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
$ xrandr -s 1440x900
Size 1440x900 not found in available modes
However I am perfectly able to set this resolution using nvidia-settings and after that xrandr can also set this display resolution.
This looks like a bug to me.
I’m running NVIDIA drivers 415.27 under Fedora 29 (fully updated).
xrandr -s uses the old RandR 1.1 protocol. Does it work if you use the RandR 1.2 protocol?
xrandr --output HDMI-0 --mode 1440x900
It might be interesting to see the output of “xrandr --q1” before and after setting it with nvidia-settings to see how the MetaMode list is changing and how it affects the RandR 1.1 protocol.
xrandr --q1
SZ: Pixels Physical Refresh
*0 1920 x 1080 ( 513mm x 291mm ) 50 51 52 53 54 55 56 *58
1 1680 x 1050 ( 449mm x 283mm ) 57
2 1440 x 900 ( 385mm x 243mm ) 59
3 1400 x 1050 ( 374mm x 283mm ) 60
4 1280 x 1024 ( 342mm x 276mm ) 61
5 1280 x 800 ( 342mm x 216mm ) 62
6 1280 x 720 ( 342mm x 194mm ) 63 64 65
7 1152 x 864 ( 308mm x 233mm ) 66
8 1024 x 768 ( 273mm x 207mm ) 67
9 800 x 600 ( 213mm x 162mm ) 68
10 720 x 576 ( 192mm x 155mm ) 69
11 720 x 480 ( 192mm x 129mm ) 70
12 640 x 480 ( 171mm x 129mm ) 71 72
13 1366 x 768 ( 365mm x 207mm ) 73
Current rotation - normal
Current reflection - none
Rotations possible - normal left inverted right
Reflections possible - X Axis Y Axis
After
xrandr --q1
*0 1920 x 1080 ( 513mm x 291mm ) *50 58 52 53 54 55 56
2 1600 x 900 ( 427mm x 243mm ) 74
3 1440 x 900 ( 385mm x 243mm ) 59
4 1400 x 1050 ( 374mm x 283mm ) 60
5 1280 x 1024 ( 342mm x 276mm ) 61
6 1280 x 800 ( 342mm x 216mm ) 62
7 1280 x 720 ( 342mm x 194mm ) 63 64 65
8 1152 x 864 ( 308mm x 233mm ) 66
9 1024 x 768 ( 273mm x 207mm ) 67
10 800 x 600 ( 213mm x 162mm ) 68
11 720 x 576 ( 192mm x 155mm ) 69
12 720 x 480 ( 192mm x 129mm ) 70
13 640 x 480 ( 171mm x 129mm ) 71 72
14 1366 x 768 ( 365mm x 207mm ) 73
Depending on a day of the week it cannot set either 1440x900 or 1600x900 resolutions.
