After the latest updates ~2 weeks ago, my xrandr stoped working with
xrandr --fb 5360x1440 --output DP-1-2 --gamma 1.0:1.0:1.0 --mode 3440x1440 --pos 0x0 --primary --rate 59.97 --reflect normal --rotate normal --output eDP-1 --gamma 1.0:1.0:1.0 --mode 1920x1080 --pos 3440x360 --rate 60.00 --reflect normal --rotate normal
xrandr: Configure crtc 3 failed
Some logs that stood out:
[ 24782.830] (WW) NVIDIA(G0): Failed to set the display configuration
[ 24782.831] (WW) NVIDIA(G0): - Setting a mode on head 0 failed: Insufficient permissions
[ 24782.831] (WW) NVIDIA(G0): - Setting a mode on head 1 failed: Insufficient permissions
[ 24782.831] (WW) NVIDIA(G0): - Setting a mode on head 2 failed: Insufficient permissions
[ 24782.831] (WW) NVIDIA(G0): - Setting a mode on head 3 failed: Insufficient permissions
[ 24782.844] (II) NVIDIA(GPU-0): Deleting GPU-0
[ 217.344678] [drm:nv_drm_dumb_map_offset [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for mapping: 0x00000006
[ 217.344701] [drm:nv_drm_dumb_map_offset [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to lookup gem object for mapping: 0x00000007
Manjaro automatically installs prime, instead of video-nvidia. I also noticed that my /etc/X11/mhwd.d/nvidia.conf
is empty, but I’m not sure if that matters. It also seemed to be empty in my backups.
Any ideas how to fix this?
nvidia-bug-report.log (1.6 MB)
