Xsense MTI -3 NOT connecting with Jetpack 6
We are trying to run the Xsens MTI-3 on our Jetpack 6 on our Jetson Orin Nano, but we recieve an error.
tarting Xsens ROS2 Driver
[INFO] [launch]: All log files can be found below /home/c9-jetson1/.ros/log/2025-03-17-22-08-14-265721-c9jetson1-desktop-8908
[INFO] [launch]: Default logging verbosity is set to INFO
[INFO] [xsens_mti_node-1]: process started with pid [8909]
[xsens_mti_node-1] RCUTILS_CONSOLE_STDOUT_LINE_BUFFERED is now ignored. Please set RCUTILS_LOGGING_USE_STDOUT and RCUTILS_LOGGING_BUFFERED_STREAM to control the stream and the buffering of log messages.
[xsens_mti_node-1] [INFO] [1742263694.411315375] [xsens_mti_node]: Creating XsControl object...
[xsens_mti_node-1] [INFO] [1742263694.421659178] [xsens_mti_node]: Scanning for devices...
[xsens_mti_node-1] [ERROR] [1742263694.471474549] [xsens_mti_node.xs]: messageextractor.cpp:183 processNewData : Skipping 15 bytes from the input buffer
[xsens_mti_node-1] [ERROR] [1742263694.471567704] [xsens_mti_node.xs]: communicator.cpp:205 handleMessage : Error message received: FAFF42012995
[xsens_mti_node-1] [ERROR] [1742263694.471585720] [xsens_mti_node.xs]: communicator.cpp:205 handleMessage : Error message received: FAFF42012995
[xsens_mti_node-1] [ERROR] [1742263694.471597336] [xsens_mti_node.xs]: communicator.cpp:205 handleMessage : Error message received: FAFF42012995
[xsens_mti_node-1] [ERROR] [1742263694.562148890] [xsens_mti_node.xs]: communicator.cpp:205 handleMessage : Error message received: FAFF42012995
[xsens_mti_node-1] [ERROR] [1742263694.570116748] [xsens_mti_node.xs]: devicecommunicator.cpp:134 doTransaction : Timeout waiting for reply to 48, timeout = 100 ms.
[xsens_mti_node-1] [ERROR] [1742263694.570165454] [xsens_mti_node.xs]: devicecommunicator.cpp:220 gotoConfig : Failed to go to config, XRV: 259
However, we did run the Xsens MTI-1 on the Jetpack 5 successfully. Is the newest version of Jetpack 6 unable to recieve IMU data successfully?
Would suggest check if there is additional configs need to be enabled for the device. And refer to developer guide to enabled required configs and rebuild kernel:
Kernel Customization — NVIDIA Jetson Linux Developer Guide
Thank you so much for your response! Is Jetpack 6 even compatible with the MTI-3 IMU device?
Hi @sbanda1, I am a Sr. Field Application Engineer at Xsens by Movella. We have tested our MTi devices with Jetpack 6, and they are compatible. Please refer to the resources below:
