[YOCTO] Download libcudnn8_8.2.1.32-1+cuda10.2_arm64.deb
Hello support,
Let me point out the following problem to you.
I cannot download the libcudnn8_8.2.1.32-1+cuda10.2_arm64.deb package.
Here are the logs:
--2024-02-08 08:05:13--  https://repo.download.nvidia.com/jetson/common/pool/main/c/cudnn/libcudnn8_8.2.1.32-1+cuda10.2_arm64.deb
Resolving repo.download.nvidia.com (repo.download.nvidia.com)... 2.23.13.4, 2.23.13.20
Connecting to repo.download.nvidia.com (repo.download.nvidia.com)|2.23.13.4|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 284693966 (272M) [application/x-debian-package]
Saving to: ‘/media/sylvain/elistair_disk/elistair/xxxx/yocto/ws/build/downloads/libcudnn8_8.2.1.32-1+cuda10.2_arm64.deb’
2024-02-08 08:05:14 (2.17 MB/s) - Connection closed at byte 1048576. Retrying.
--2024-02-08 08:05:15--  (try: 2)  https://repo.download.nvidia.com/jetson/common/pool/main/c/cudnn/libcudnn8_8.2.1.32-1+cuda10.2_arm64.deb
HTTP request sent, awaiting response... 206 Partial Content
Length: 284693966 (272M), 283645390 (271M) remaining [application/x-debian-package]
        [ skipping 1000K ]
  1000K ,,,,,,,,,, ,,,,,,,,,, ,,,,                              0% 0.00 =0s
2024-02-08 08:05:15 (0.00 B/s) - Connection closed at byte 1048576. Giving up.
The NVIDIA server responds that the file size is: Length: 284693966 (272M) [application/x-debian-package]
But the server always ends the download after around 1M: Connection closed at byte 1048576
I also tried downloading the package directly from my Firefox browser and I have the same problem.
Thank you in advance for your support
Best regards,
Sylvain
The issue is solved.
Could you check it again?
