Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other Yocto OpenEmbeded
Hardware Platform
other p3710-10-s05
SDK Manager Version
2.1.0
other don’t know
Host Machine Version
[ X ] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
Issue Description
Hi NVIDIA friends,
We’re from Amazon, and we’re working on building an edge computing system using the ORIN Drive box to run ML-based workloads within Podman containers.
We successfully completed a POC (reference)with an Ubuntu-based ORIN Drive Box, where we managed to run sample CUDA applications inside a --privileged
Podman container. We verified that these CUDA samples in isolated containers could access the SOC GPU on the host by using the NVIDIA Container Toolkit to mount the NVIDIA drivers from the host into the Podman container.
However, we’ve encountered a challenge: our production ORIN Drive Box will run a custom Yocto OpenEmbedded OS rather than Ubuntu.
According to this NVIDIA-container-toolkit documentation, NVIDIA Container Toolkit versions 1.12 and above are required to patch the container runtime for creating GPU-accelerated Podman containers. Unfortunately, the available documentation starts from version 1.14+, and the latest NVIDIA Container Toolkit version available in the OpenEmbedded meta-tegra layer is v1.11.
This is problematic for us, as we need GPU-accelerated Podman containers to productionize our Yocto OS-based edge system. Is there a way to enable GPU acceleration in Podman containers given these constraints?
Any insights or guidance would be greatly appreciated.
Thank you!
