When I tried to run YOLO v2 with yolo-voc.cfg and yolo-voc.weights on Nvida Jetson TX1 (Ubutu 16.04, JetPack-L4T-2.3.1 and nvcc 8.0), YOLO has been killed after loading layer 27. (i.e. the error message is “28 Killed”). I compiled YOLO with CUDNN=1 and OPENCV=1 on Jetson TX1. However, there is no problem on my desktop (Ubuntu 14.04, nvcc 8.0)
Thank you for your comments. The problem was out of memory. When I changed batch from 64 to 1 and subdivisions from 8 to 1, there is no problem on Jetson TX1. Could you explain what is “batch” and “subdivisions” in YOLO v2?
I do not know about YOLO, someone else will have to comment. Typically such software uses multiple threads or multiple GPU kernels at once and offers to set a cap on maximum threads/kernels…this is likely what your options do is cap max threads or GPU kernels (or recursion depth).
Batch size means the number of images algorithm process at a time, subdivisions is used to divide the total work into real GPU jobs.
For examples,
Set batch size to 64 means algorithm will update weight every 64 images.
Set subdivision to 2 means to divide the total work into 2 gpu jobs:
Gpu process 32 images each time
Algorithm update weight after two GPU jobs are done.
More images process at a time means more memory usage.
I installed yolo demo from below github link and it worked with jetson TX2 onboard camera, but FPS is 2.5 maximum. How can I increase FPS? Why is FPS too low?
