1.Ubuntu system might be a problem?
2. Hardware damage?
3. command “jtop”, print cuda error information.
What power supply are you using? We were running a board off of a cheap Amazon power supply and it would give strange CUDA errors when the load got higher. See if it reproduces for you using the included power brick first.
As jakepoz suggest, could you share which power supply do you use?
