Have you tried to update your python3 ‘protobuf’ module?
updating protobuf did help
then got one more error after running onnx_to_tensorrt.py
Loading ONNX file from path yolov3-416.onnx...
Beginning ONNX file parsing
Completed parsing of ONNX file
Building an engine from file yolov3-416.onnx; this may take a while...
[TensorRT] ERROR: Network must have at least one output
[TensorRT] ERROR: Network validation failed.
Completed creating Engine
File "onnx_to_tensorrt.py", line 102, in <module>
main()
File "onnx_to_tensorrt.py", line 98, in main
_ = build_engine(onnx_file_path, engine_file_path)
File "onnx_to_tensorrt.py", line 84, in build_engine
f.write(engine.serialize())
AttributeError: 'NoneType' object has no attribute 'serialize'
I don’t know why you encounter this error.
You need to check why the generated ONNX model does not have outputs. Check source code around this line: https://github.com/jkjung-avt/tensorrt_demos/blob/master/yolov3_onnx/yolov3_to_onnx.py#L800
I tried the same pdb
python3 -m pdb onnx_totensorrt.py -m yolov3-416
I get this
main()
realmentlabs@realmentlabs-To-be-filled-by-O-E-M:~/tensorrt_demos/yolov3_onnx$ python3 -m pdb onnx_to_tensorrt.py --model yolov3-416
> /home/mysystem/tensorrt_demos/yolov3_onnx/onnx_to_tensorrt.py(51)<module>()
-> from __future__ import print_function
(Pdb) c
File "/usr/lib/python3.6/pdb.py", line 1667, in main
pdb._runscript(mainpyfile)
File "/usr/lib/python3.6/pdb.py", line 1548, in _runscript
self.run(statement)
File "/usr/lib/python3.6/bdb.py", line 434, in run
exec(cmd, globals, locals)
File "<string>", line 1, in <module>
File "/home/mysystem/tensorrt_demos/yolov3_onnx/onnx_to_tensorrt.py", line 51, in <module>
File "/home/mysystem/tensorrt_demos/yolov3_onnx/onnx_to_tensorrt.py", line 98, in main
File "/home/mysystem/tensorrt_demos/yolov3_onnx/onnx_to_tensorrt.py", line 84, in build_engine
Uncaught exception. Entering post mortem debugging
Running 'cont' or 'step' will restart the program
> /home/mysystem/tensorrt_demos/yolov3_onnx/onnx_to_tensorrt.py(84)build_engine()
-> f.write(engine.serialize())
(Pdb) p f
<_io.BufferedWriter name='yolov3-416.trt'>
(Pdb) p engine_file_path
'yolov3-416.trt'
(Pdb) p engine
None
(Pdb) p network
<tensorrt.tensorrt.INetworkDefinition object at 0x7f4f2f469148>
(Pdb)
engine is not getting created
I think this error means you are still having problem with the previous step (yolov3_to_onnx). The generated ONNX model does not have any output node. You need to fix that first.
Did you notice any error/warning messages after you updated ‘protobuf’ and ran python3 yolov3_to_onnx.py --model yolov3-416 again?
I get this output upon running the yolov3_to_onnx.py
Layer of type yolo not supported, skipping ONNX node generation.
graph yolov3-416 (
%000_net[FLOAT, 64x3x416x416]
) initializers (
%001_convolutional_bn_scale[FLOAT, 32]
%001_convolutional_bn_bias[FLOAT, 32]
%001_convolutional_bn_mean[FLOAT, 32]
%001_convolutional_bn_var[FLOAT, 32]
%001_convolutional_conv_weights[FLOAT, 32x3x3x3]
%002_convolutional_bn_scale[FLOAT, 64]
%002_convolutional_bn_bias[FLOAT, 64]
%002_convolutional_bn_mean[FLOAT, 64]
%002_convolutional_bn_var[FLOAT, 64]
%002_convolutional_conv_weights[FLOAT, 64x32x3x3]
%003_convolutional_bn_scale[FLOAT, 32]
%003_convolutional_bn_bias[FLOAT, 32]
%003_convolutional_bn_mean[FLOAT, 32]
%003_convolutional_bn_var[FLOAT, 32]
%003_convolutional_conv_weights[FLOAT, 32x64x1x1]
%004_convolutional_bn_scale[FLOAT, 64]
%004_convolutional_bn_bias[FLOAT, 64]
%004_convolutional_bn_mean[FLOAT, 64]
%004_convolutional_bn_var[FLOAT, 64]
%004_convolutional_conv_weights[FLOAT, 64x32x3x3]
%006_convolutional_bn_scale[FLOAT, 128]
%006_convolutional_bn_bias[FLOAT, 128]
%006_convolutional_bn_mean[FLOAT, 128]
%006_convolutional_bn_var[FLOAT, 128]
%006_convolutional_conv_weights[FLOAT, 128x64x3x3]
%007_convolutional_bn_scale[FLOAT, 64]
%007_convolutional_bn_bias[FLOAT, 64]
%007_convolutional_bn_mean[FLOAT, 64]
%007_convolutional_bn_var[FLOAT, 64]
%007_convolutional_conv_weights[FLOAT, 64x128x1x1]
%008_convolutional_bn_scale[FLOAT, 128]
%008_convolutional_bn_bias[FLOAT, 128]
%008_convolutional_bn_mean[FLOAT, 128]
%008_convolutional_bn_var[FLOAT, 128]
%008_convolutional_conv_weights[FLOAT, 128x64x3x3]
%010_convolutional_bn_scale[FLOAT, 64]
%010_convolutional_bn_bias[FLOAT, 64]
%010_convolutional_bn_mean[FLOAT, 64]
%010_convolutional_bn_var[FLOAT, 64]
%010_convolutional_conv_weights[FLOAT, 64x128x1x1]
%011_convolutional_bn_scale[FLOAT, 128]
%011_convolutional_bn_bias[FLOAT, 128]
%011_convolutional_bn_mean[FLOAT, 128]
%011_convolutional_bn_var[FLOAT, 128]
%011_convolutional_conv_weights[FLOAT, 128x64x3x3]
%013_convolutional_bn_scale[FLOAT, 256]
%013_convolutional_bn_bias[FLOAT, 256]
%013_convolutional_bn_mean[FLOAT, 256]
%013_convolutional_bn_var[FLOAT, 256]
%013_convolutional_conv_weights[FLOAT, 256x128x3x3]
%014_convolutional_bn_scale[FLOAT, 128]
%014_convolutional_bn_bias[FLOAT, 128]
%014_convolutional_bn_mean[FLOAT, 128]
%014_convolutional_bn_var[FLOAT, 128]
%014_convolutional_conv_weights[FLOAT, 128x256x1x1]
%015_convolutional_bn_scale[FLOAT, 256]
%015_convolutional_bn_bias[FLOAT, 256]
%015_convolutional_bn_mean[FLOAT, 256]
%015_convolutional_bn_var[FLOAT, 256]
%015_convolutional_conv_weights[FLOAT, 256x128x3x3]
%017_convolutional_bn_scale[FLOAT, 128]
%017_convolutional_bn_bias[FLOAT, 128]
%017_convolutional_bn_mean[FLOAT, 128]
%017_convolutional_bn_var[FLOAT, 128]
%017_convolutional_conv_weights[FLOAT, 128x256x1x1]
%018_convolutional_bn_scale[FLOAT, 256]
%018_convolutional_bn_bias[FLOAT, 256]
%018_convolutional_bn_mean[FLOAT, 256]
%018_convolutional_bn_var[FLOAT, 256]
%018_convolutional_conv_weights[FLOAT, 256x128x3x3]
%020_convolutional_bn_scale[FLOAT, 128]
%020_convolutional_bn_bias[FLOAT, 128]
%020_convolutional_bn_mean[FLOAT, 128]
%020_convolutional_bn_var[FLOAT, 128]
%020_convolutional_conv_weights[FLOAT, 128x256x1x1]
%021_convolutional_bn_scale[FLOAT, 256]
%021_convolutional_bn_bias[FLOAT, 256]
%021_convolutional_bn_mean[FLOAT, 256]
%021_convolutional_bn_var[FLOAT, 256]
%021_convolutional_conv_weights[FLOAT, 256x128x3x3]
%023_convolutional_bn_scale[FLOAT, 128]
%023_convolutional_bn_bias[FLOAT, 128]
%023_convolutional_bn_mean[FLOAT, 128]
%023_convolutional_bn_var[FLOAT, 128]
%023_convolutional_conv_weights[FLOAT, 128x256x1x1]
%024_convolutional_bn_scale[FLOAT, 256]
%024_convolutional_bn_bias[FLOAT, 256]
%024_convolutional_bn_mean[FLOAT, 256]
%024_convolutional_bn_var[FLOAT, 256]
%024_convolutional_conv_weights[FLOAT, 256x128x3x3]
%026_convolutional_bn_scale[FLOAT, 128]
%026_convolutional_bn_bias[FLOAT, 128]
%026_convolutional_bn_mean[FLOAT, 128]
%026_convolutional_bn_var[FLOAT, 128]
%026_convolutional_conv_weights[FLOAT, 128x256x1x1]
%027_convolutional_bn_scale[FLOAT, 256]
%027_convolutional_bn_bias[FLOAT, 256]
%027_convolutional_bn_mean[FLOAT, 256]
%027_convolutional_bn_var[FLOAT, 256]
%027_convolutional_conv_weights[FLOAT, 256x128x3x3]
%029_convolutional_bn_scale[FLOAT, 128]
%029_convolutional_bn_bias[FLOAT, 128]
%029_convolutional_bn_mean[FLOAT, 128]
%029_convolutional_bn_var[FLOAT, 128]
%029_convolutional_conv_weights[FLOAT, 128x256x1x1]
%030_convolutional_bn_scale[FLOAT, 256]
%030_convolutional_bn_bias[FLOAT, 256]
%030_convolutional_bn_mean[FLOAT, 256]
%030_convolutional_bn_var[FLOAT, 256]
%030_convolutional_conv_weights[FLOAT, 256x128x3x3]
%032_convolutional_bn_scale[FLOAT, 128]
%032_convolutional_bn_bias[FLOAT, 128]
%032_convolutional_bn_mean[FLOAT, 128]
%032_convolutional_bn_var[FLOAT, 128]
%032_convolutional_conv_weights[FLOAT, 128x256x1x1]
%033_convolutional_bn_scale[FLOAT, 256]
%033_convolutional_bn_bias[FLOAT, 256]
%033_convolutional_bn_mean[FLOAT, 256]
%033_convolutional_bn_var[FLOAT, 256]
%033_convolutional_conv_weights[FLOAT, 256x128x3x3]
%035_convolutional_bn_scale[FLOAT, 128]
%035_convolutional_bn_bias[FLOAT, 128]
%035_convolutional_bn_mean[FLOAT, 128]
%035_convolutional_bn_var[FLOAT, 128]
%035_convolutional_conv_weights[FLOAT, 128x256x1x1]
%036_convolutional_bn_scale[FLOAT, 256]
%036_convolutional_bn_bias[FLOAT, 256]
%036_convolutional_bn_mean[FLOAT, 256]
%036_convolutional_bn_var[FLOAT, 256]
%036_convolutional_conv_weights[FLOAT, 256x128x3x3]
%038_convolutional_bn_scale[FLOAT, 512]
%038_convolutional_bn_bias[FLOAT, 512]
%038_convolutional_bn_mean[FLOAT, 512]
%038_convolutional_bn_var[FLOAT, 512]
%038_convolutional_conv_weights[FLOAT, 512x256x3x3]
%039_convolutional_bn_scale[FLOAT, 256]
%039_convolutional_bn_bias[FLOAT, 256]
%039_convolutional_bn_mean[FLOAT, 256]
%039_convolutional_bn_var[FLOAT, 256]
%039_convolutional_conv_weights[FLOAT, 256x512x1x1]
%040_convolutional_bn_scale[FLOAT, 512]
%040_convolutional_bn_bias[FLOAT, 512]
%040_convolutional_bn_mean[FLOAT, 512]
%040_convolutional_bn_var[FLOAT, 512]
%040_convolutional_conv_weights[FLOAT, 512x256x3x3]
%042_convolutional_bn_scale[FLOAT, 256]
%042_convolutional_bn_bias[FLOAT, 256]
%042_convolutional_bn_mean[FLOAT, 256]
%042_convolutional_bn_var[FLOAT, 256]
%042_convolutional_conv_weights[FLOAT, 256x512x1x1]
%043_convolutional_bn_scale[FLOAT, 512]
%043_convolutional_bn_bias[FLOAT, 512]
%043_convolutional_bn_mean[FLOAT, 512]
%043_convolutional_bn_var[FLOAT, 512]
%043_convolutional_conv_weights[FLOAT, 512x256x3x3]
%045_convolutional_bn_scale[FLOAT, 256]
%045_convolutional_bn_bias[FLOAT, 256]
%045_convolutional_bn_mean[FLOAT, 256]
%045_convolutional_bn_var[FLOAT, 256]
%045_convolutional_conv_weights[FLOAT, 256x512x1x1]
%046_convolutional_bn_scale[FLOAT, 512]
%046_convolutional_bn_bias[FLOAT, 512]
%046_convolutional_bn_mean[FLOAT, 512]
%046_convolutional_bn_var[FLOAT, 512]
%046_convolutional_conv_weights[FLOAT, 512x256x3x3]
%048_convolutional_bn_scale[FLOAT, 256]
%048_convolutional_bn_bias[FLOAT, 256]
%048_convolutional_bn_mean[FLOAT, 256]
%048_convolutional_bn_var[FLOAT, 256]
%048_convolutional_conv_weights[FLOAT, 256x512x1x1]
%049_convolutional_bn_scale[FLOAT, 512]
%049_convolutional_bn_bias[FLOAT, 512]
%049_convolutional_bn_mean[FLOAT, 512]
%049_convolutional_bn_var[FLOAT, 512]
%049_convolutional_conv_weights[FLOAT, 512x256x3x3]
%051_convolutional_bn_scale[FLOAT, 256]
%051_convolutional_bn_bias[FLOAT, 256]
%051_convolutional_bn_mean[FLOAT, 256]
%051_convolutional_bn_var[FLOAT, 256]
%051_convolutional_conv_weights[FLOAT, 256x512x1x1]
%052_convolutional_bn_scale[FLOAT, 512]
%052_convolutional_bn_bias[FLOAT, 512]
%052_convolutional_bn_mean[FLOAT, 512]
%052_convolutional_bn_var[FLOAT, 512]
%052_convolutional_conv_weights[FLOAT, 512x256x3x3]
%054_convolutional_bn_scale[FLOAT, 256]
%054_convolutional_bn_bias[FLOAT, 256]
%054_convolutional_bn_mean[FLOAT, 256]
%054_convolutional_bn_var[FLOAT, 256]
%054_convolutional_conv_weights[FLOAT, 256x512x1x1]
%055_convolutional_bn_scale[FLOAT, 512]
%055_convolutional_bn_bias[FLOAT, 512]
%055_convolutional_bn_mean[FLOAT, 512]
%055_convolutional_bn_var[FLOAT, 512]
%055_convolutional_conv_weights[FLOAT, 512x256x3x3]
%057_convolutional_bn_scale[FLOAT, 256]
%057_convolutional_bn_bias[FLOAT, 256]
%057_convolutional_bn_mean[FLOAT, 256]
%057_convolutional_bn_var[FLOAT, 256]
%057_convolutional_conv_weights[FLOAT, 256x512x1x1]
%058_convolutional_bn_scale[FLOAT, 512]
%058_convolutional_bn_bias[FLOAT, 512]
%058_convolutional_bn_mean[FLOAT, 512]
%058_convolutional_bn_var[FLOAT, 512]
%058_convolutional_conv_weights[FLOAT, 512x256x3x3]
%060_convolutional_bn_scale[FLOAT, 256]
%060_convolutional_bn_bias[FLOAT, 256]
%060_convolutional_bn_mean[FLOAT, 256]
%060_convolutional_bn_var[FLOAT, 256]
%060_convolutional_conv_weights[FLOAT, 256x512x1x1]
%061_convolutional_bn_scale[FLOAT, 512]
%061_convolutional_bn_bias[FLOAT, 512]
%061_convolutional_bn_mean[FLOAT, 512]
%061_convolutional_bn_var[FLOAT, 512]
%061_convolutional_conv_weights[FLOAT, 512x256x3x3]
%063_convolutional_bn_scale[FLOAT, 1024]
%063_convolutional_bn_bias[FLOAT, 1024]
%063_convolutional_bn_mean[FLOAT, 1024]
%063_convolutional_bn_var[FLOAT, 1024]
%063_convolutional_conv_weights[FLOAT, 1024x512x3x3]
%064_convolutional_bn_scale[FLOAT, 512]
%064_convolutional_bn_bias[FLOAT, 512]
%064_convolutional_bn_mean[FLOAT, 512]
%064_convolutional_bn_var[FLOAT, 512]
%064_convolutional_conv_weights[FLOAT, 512x1024x1x1]
%065_convolutional_bn_scale[FLOAT, 1024]
%065_convolutional_bn_bias[FLOAT, 1024]
%065_convolutional_bn_mean[FLOAT, 1024]
%065_convolutional_bn_var[FLOAT, 1024]
%065_convolutional_conv_weights[FLOAT, 1024x512x3x3]
%067_convolutional_bn_scale[FLOAT, 512]
%067_convolutional_bn_bias[FLOAT, 512]
%067_convolutional_bn_mean[FLOAT, 512]
%067_convolutional_bn_var[FLOAT, 512]
%067_convolutional_conv_weights[FLOAT, 512x1024x1x1]
%068_convolutional_bn_scale[FLOAT, 1024]
%068_convolutional_bn_bias[FLOAT, 1024]
%068_convolutional_bn_mean[FLOAT, 1024]
%068_convolutional_bn_var[FLOAT, 1024]
%068_convolutional_conv_weights[FLOAT, 1024x512x3x3]
%070_convolutional_bn_scale[FLOAT, 512]
%070_convolutional_bn_bias[FLOAT, 512]
%070_convolutional_bn_mean[FLOAT, 512]
%070_convolutional_bn_var[FLOAT, 512]
%070_convolutional_conv_weights[FLOAT, 512x1024x1x1]
%071_convolutional_bn_scale[FLOAT, 1024]
%071_convolutional_bn_bias[FLOAT, 1024]
%071_convolutional_bn_mean[FLOAT, 1024]
%071_convolutional_bn_var[FLOAT, 1024]
%071_convolutional_conv_weights[FLOAT, 1024x512x3x3]
%073_convolutional_bn_scale[FLOAT, 512]
%073_convolutional_bn_bias[FLOAT, 512]
%073_convolutional_bn_mean[FLOAT, 512]
%073_convolutional_bn_var[FLOAT, 512]
%073_convolutional_conv_weights[FLOAT, 512x1024x1x1]
%074_convolutional_bn_scale[FLOAT, 1024]
%074_convolutional_bn_bias[FLOAT, 1024]
%074_convolutional_bn_mean[FLOAT, 1024]
%074_convolutional_bn_var[FLOAT, 1024]
%074_convolutional_conv_weights[FLOAT, 1024x512x3x3]
%076_convolutional_bn_scale[FLOAT, 512]
%076_convolutional_bn_bias[FLOAT, 512]
%076_convolutional_bn_mean[FLOAT, 512]
%076_convolutional_bn_var[FLOAT, 512]
%076_convolutional_conv_weights[FLOAT, 512x1024x1x1]
%077_convolutional_bn_scale[FLOAT, 1024]
%077_convolutional_bn_bias[FLOAT, 1024]
%077_convolutional_bn_mean[FLOAT, 1024]
%077_convolutional_bn_var[FLOAT, 1024]
%077_convolutional_conv_weights[FLOAT, 1024x512x3x3]
%078_convolutional_bn_scale[FLOAT, 512]
%078_convolutional_bn_bias[FLOAT, 512]
%078_convolutional_bn_mean[FLOAT, 512]
%078_convolutional_bn_var[FLOAT, 512]
%078_convolutional_conv_weights[FLOAT, 512x1024x1x1]
%079_convolutional_bn_scale[FLOAT, 1024]
%079_convolutional_bn_bias[FLOAT, 1024]
%079_convolutional_bn_mean[FLOAT, 1024]
%079_convolutional_bn_var[FLOAT, 1024]
%079_convolutional_conv_weights[FLOAT, 1024x512x3x3]
%080_convolutional_bn_scale[FLOAT, 512]
%080_convolutional_bn_bias[FLOAT, 512]
%080_convolutional_bn_mean[FLOAT, 512]
%080_convolutional_bn_var[FLOAT, 512]
%080_convolutional_conv_weights[FLOAT, 512x1024x1x1]
%081_convolutional_bn_scale[FLOAT, 1024]
%081_convolutional_bn_bias[FLOAT, 1024]
%081_convolutional_bn_mean[FLOAT, 1024]
%081_convolutional_bn_var[FLOAT, 1024]
%081_convolutional_conv_weights[FLOAT, 1024x512x3x3]
%082_convolutional_conv_bias[FLOAT, 255]
%082_convolutional_conv_weights[FLOAT, 255x1024x1x1]
%085_convolutional_bn_scale[FLOAT, 256]
%085_convolutional_bn_bias[FLOAT, 256]
%085_convolutional_bn_mean[FLOAT, 256]
%085_convolutional_bn_var[FLOAT, 256]
%085_convolutional_conv_weights[FLOAT, 256x512x1x1]
%086_upsample_scale[FLOAT, 4]
%088_convolutional_bn_scale[FLOAT, 256]
%088_convolutional_bn_bias[FLOAT, 256]
%088_convolutional_bn_mean[FLOAT, 256]
%088_convolutional_bn_var[FLOAT, 256]
%088_convolutional_conv_weights[FLOAT, 256x768x1x1]
%089_convolutional_bn_scale[FLOAT, 512]
%089_convolutional_bn_bias[FLOAT, 512]
%089_convolutional_bn_mean[FLOAT, 512]
%089_convolutional_bn_var[FLOAT, 512]
%089_convolutional_conv_weights[FLOAT, 512x256x3x3]
%090_convolutional_bn_scale[FLOAT, 256]
%090_convolutional_bn_bias[FLOAT, 256]
%090_convolutional_bn_mean[FLOAT, 256]
%090_convolutional_bn_var[FLOAT, 256]
%090_convolutional_conv_weights[FLOAT, 256x512x1x1]
%091_convolutional_bn_scale[FLOAT, 512]
%091_convolutional_bn_bias[FLOAT, 512]
%091_convolutional_bn_mean[FLOAT, 512]
%091_convolutional_bn_var[FLOAT, 512]
%091_convolutional_conv_weights[FLOAT, 512x256x3x3]
%092_convolutional_bn_scale[FLOAT, 256]
%092_convolutional_bn_bias[FLOAT, 256]
%092_convolutional_bn_mean[FLOAT, 256]
%092_convolutional_bn_var[FLOAT, 256]
%092_convolutional_conv_weights[FLOAT, 256x512x1x1]
%093_convolutional_bn_scale[FLOAT, 512]
%093_convolutional_bn_bias[FLOAT, 512]
%093_convolutional_bn_mean[FLOAT, 512]
%093_convolutional_bn_var[FLOAT, 512]
%093_convolutional_conv_weights[FLOAT, 512x256x3x3]
%094_convolutional_conv_bias[FLOAT, 255]
%094_convolutional_conv_weights[FLOAT, 255x512x1x1]
%097_convolutional_bn_scale[FLOAT, 128]
%097_convolutional_bn_bias[FLOAT, 128]
%097_convolutional_bn_mean[FLOAT, 128]
%097_convolutional_bn_var[FLOAT, 128]
%097_convolutional_conv_weights[FLOAT, 128x256x1x1]
%098_upsample_scale[FLOAT, 4]
%100_convolutional_bn_scale[FLOAT, 128]
%100_convolutional_bn_bias[FLOAT, 128]
%100_convolutional_bn_mean[FLOAT, 128]
%100_convolutional_bn_var[FLOAT, 128]
%100_convolutional_conv_weights[FLOAT, 128x384x1x1]
%101_convolutional_bn_scale[FLOAT, 256]
%101_convolutional_bn_bias[FLOAT, 256]
%101_convolutional_bn_mean[FLOAT, 256]
%101_convolutional_bn_var[FLOAT, 256]
%101_convolutional_conv_weights[FLOAT, 256x128x3x3]
%102_convolutional_bn_scale[FLOAT, 128]
%102_convolutional_bn_bias[FLOAT, 128]
%102_convolutional_bn_mean[FLOAT, 128]
%102_convolutional_bn_var[FLOAT, 128]
%102_convolutional_conv_weights[FLOAT, 128x256x1x1]
%103_convolutional_bn_scale[FLOAT, 256]
%103_convolutional_bn_bias[FLOAT, 256]
%103_convolutional_bn_mean[FLOAT, 256]
%103_convolutional_bn_var[FLOAT, 256]
%103_convolutional_conv_weights[FLOAT, 256x128x3x3]
%104_convolutional_bn_scale[FLOAT, 128]
%104_convolutional_bn_bias[FLOAT, 128]
%104_convolutional_bn_mean[FLOAT, 128]
%104_convolutional_bn_var[FLOAT, 128]
%104_convolutional_conv_weights[FLOAT, 128x256x1x1]
%105_convolutional_bn_scale[FLOAT, 256]
%105_convolutional_bn_bias[FLOAT, 256]
%105_convolutional_bn_mean[FLOAT, 256]
%105_convolutional_bn_var[FLOAT, 256]
%105_convolutional_conv_weights[FLOAT, 256x128x3x3]
%106_convolutional_conv_bias[FLOAT, 255]
%106_convolutional_conv_weights[FLOAT, 255x256x1x1]
%001_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%000_net, %001_convolutional_conv_weights)
%001_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%001_convolutional, %001_convolutional_bn_scale, %001_convolutional_bn_bias, %001_convolutional_bn_mean, %001_convolutional_bn_var)
%001_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%001_convolutional_bn)
%002_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [2, 2]](%001_convolutional_lrelu, %002_convolutional_conv_weights)
%002_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%002_convolutional, %002_convolutional_bn_scale, %002_convolutional_bn_bias, %002_convolutional_bn_mean, %002_convolutional_bn_var)
%002_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%002_convolutional_bn)
%003_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%002_convolutional_lrelu, %003_convolutional_conv_weights)
%003_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%003_convolutional, %003_convolutional_bn_scale, %003_convolutional_bn_bias, %003_convolutional_bn_mean, %003_convolutional_bn_var)
%003_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%003_convolutional_bn)
%004_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%003_convolutional_lrelu, %004_convolutional_conv_weights)
%004_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%004_convolutional, %004_convolutional_bn_scale, %004_convolutional_bn_bias, %004_convolutional_bn_mean, %004_convolutional_bn_var)
%004_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%004_convolutional_bn)
%005_shortcut = Add(%004_convolutional_lrelu, %002_convolutional_lrelu)
%006_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [2, 2]](%005_shortcut, %006_convolutional_conv_weights)
%006_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%006_convolutional, %006_convolutional_bn_scale, %006_convolutional_bn_bias, %006_convolutional_bn_mean, %006_convolutional_bn_var)
%006_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%006_convolutional_bn)
%007_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%006_convolutional_lrelu, %007_convolutional_conv_weights)
%007_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%007_convolutional, %007_convolutional_bn_scale, %007_convolutional_bn_bias, %007_convolutional_bn_mean, %007_convolutional_bn_var)
%007_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%007_convolutional_bn)
%008_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%007_convolutional_lrelu, %008_convolutional_conv_weights)
%008_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%008_convolutional, %008_convolutional_bn_scale, %008_convolutional_bn_bias, %008_convolutional_bn_mean, %008_convolutional_bn_var)
%008_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%008_convolutional_bn)
%009_shortcut = Add(%008_convolutional_lrelu, %006_convolutional_lrelu)
%010_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%009_shortcut, %010_convolutional_conv_weights)
%010_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%010_convolutional, %010_convolutional_bn_scale, %010_convolutional_bn_bias, %010_convolutional_bn_mean, %010_convolutional_bn_var)
%010_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%010_convolutional_bn)
%011_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%010_convolutional_lrelu, %011_convolutional_conv_weights)
%011_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%011_convolutional, %011_convolutional_bn_scale, %011_convolutional_bn_bias, %011_convolutional_bn_mean, %011_convolutional_bn_var)
%011_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%011_convolutional_bn)
%012_shortcut = Add(%011_convolutional_lrelu, %009_shortcut)
%013_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [2, 2]](%012_shortcut, %013_convolutional_conv_weights)
%013_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%013_convolutional, %013_convolutional_bn_scale, %013_convolutional_bn_bias, %013_convolutional_bn_mean, %013_convolutional_bn_var)
%013_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%013_convolutional_bn)
%014_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%013_convolutional_lrelu, %014_convolutional_conv_weights)
%014_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%014_convolutional, %014_convolutional_bn_scale, %014_convolutional_bn_bias, %014_convolutional_bn_mean, %014_convolutional_bn_var)
%014_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%014_convolutional_bn)
%015_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%014_convolutional_lrelu, %015_convolutional_conv_weights)
%015_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%015_convolutional, %015_convolutional_bn_scale, %015_convolutional_bn_bias, %015_convolutional_bn_mean, %015_convolutional_bn_var)
%015_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%015_convolutional_bn)
%016_shortcut = Add(%015_convolutional_lrelu, %013_convolutional_lrelu)
%017_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%016_shortcut, %017_convolutional_conv_weights)
%017_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%017_convolutional, %017_convolutional_bn_scale, %017_convolutional_bn_bias, %017_convolutional_bn_mean, %017_convolutional_bn_var)
%017_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%017_convolutional_bn)
%018_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%017_convolutional_lrelu, %018_convolutional_conv_weights)
%018_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%018_convolutional, %018_convolutional_bn_scale, %018_convolutional_bn_bias, %018_convolutional_bn_mean, %018_convolutional_bn_var)
%018_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%018_convolutional_bn)
%019_shortcut = Add(%018_convolutional_lrelu, %016_shortcut)
%020_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%019_shortcut, %020_convolutional_conv_weights)
%020_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%020_convolutional, %020_convolutional_bn_scale, %020_convolutional_bn_bias, %020_convolutional_bn_mean, %020_convolutional_bn_var)
%020_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%020_convolutional_bn)
%021_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%020_convolutional_lrelu, %021_convolutional_conv_weights)
%021_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%021_convolutional, %021_convolutional_bn_scale, %021_convolutional_bn_bias, %021_convolutional_bn_mean, %021_convolutional_bn_var)
%021_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%021_convolutional_bn)
%022_shortcut = Add(%021_convolutional_lrelu, %019_shortcut)
%023_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%022_shortcut, %023_convolutional_conv_weights)
%023_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%023_convolutional, %023_convolutional_bn_scale, %023_convolutional_bn_bias, %023_convolutional_bn_mean, %023_convolutional_bn_var)
%023_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%023_convolutional_bn)
%024_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%023_convolutional_lrelu, %024_convolutional_conv_weights)
%024_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%024_convolutional, %024_convolutional_bn_scale, %024_convolutional_bn_bias, %024_convolutional_bn_mean, %024_convolutional_bn_var)
%024_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%024_convolutional_bn)
%025_shortcut = Add(%024_convolutional_lrelu, %022_shortcut)
%026_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%025_shortcut, %026_convolutional_conv_weights)
%026_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%026_convolutional, %026_convolutional_bn_scale, %026_convolutional_bn_bias, %026_convolutional_bn_mean, %026_convolutional_bn_var)
%026_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%026_convolutional_bn)
%027_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%026_convolutional_lrelu, %027_convolutional_conv_weights)
%027_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%027_convolutional, %027_convolutional_bn_scale, %027_convolutional_bn_bias, %027_convolutional_bn_mean, %027_convolutional_bn_var)
%027_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%027_convolutional_bn)
%028_shortcut = Add(%027_convolutional_lrelu, %025_shortcut)
%029_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%028_shortcut, %029_convolutional_conv_weights)
%029_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%029_convolutional, %029_convolutional_bn_scale, %029_convolutional_bn_bias, %029_convolutional_bn_mean, %029_convolutional_bn_var)
%029_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%029_convolutional_bn)
%030_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%029_convolutional_lrelu, %030_convolutional_conv_weights)
%030_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%030_convolutional, %030_convolutional_bn_scale, %030_convolutional_bn_bias, %030_convolutional_bn_mean, %030_convolutional_bn_var)
%030_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%030_convolutional_bn)
%031_shortcut = Add(%030_convolutional_lrelu, %028_shortcut)
%032_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%031_shortcut, %032_convolutional_conv_weights)
%032_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%032_convolutional, %032_convolutional_bn_scale, %032_convolutional_bn_bias, %032_convolutional_bn_mean, %032_convolutional_bn_var)
%032_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%032_convolutional_bn)
%033_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%032_convolutional_lrelu, %033_convolutional_conv_weights)
%033_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%033_convolutional, %033_convolutional_bn_scale, %033_convolutional_bn_bias, %033_convolutional_bn_mean, %033_convolutional_bn_var)
%033_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%033_convolutional_bn)
%034_shortcut = Add(%033_convolutional_lrelu, %031_shortcut)
%035_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%034_shortcut, %035_convolutional_conv_weights)
%035_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%035_convolutional, %035_convolutional_bn_scale, %035_convolutional_bn_bias, %035_convolutional_bn_mean, %035_convolutional_bn_var)
%035_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%035_convolutional_bn)
%036_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%035_convolutional_lrelu, %036_convolutional_conv_weights)
%036_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%036_convolutional, %036_convolutional_bn_scale, %036_convolutional_bn_bias, %036_convolutional_bn_mean, %036_convolutional_bn_var)
%036_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%036_convolutional_bn)
%037_shortcut = Add(%036_convolutional_lrelu, %034_shortcut)
%038_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [2, 2]](%037_shortcut, %038_convolutional_conv_weights)
%038_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%038_convolutional, %038_convolutional_bn_scale, %038_convolutional_bn_bias, %038_convolutional_bn_mean, %038_convolutional_bn_var)
%038_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%038_convolutional_bn)
%039_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%038_convolutional_lrelu, %039_convolutional_conv_weights)
%039_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%039_convolutional, %039_convolutional_bn_scale, %039_convolutional_bn_bias, %039_convolutional_bn_mean, %039_convolutional_bn_var)
%039_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%039_convolutional_bn)
%040_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%039_convolutional_lrelu, %040_convolutional_conv_weights)
%040_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%040_convolutional, %040_convolutional_bn_scale, %040_convolutional_bn_bias, %040_convolutional_bn_mean, %040_convolutional_bn_var)
%040_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%040_convolutional_bn)
%041_shortcut = Add(%040_convolutional_lrelu, %038_convolutional_lrelu)
%042_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%041_shortcut, %042_convolutional_conv_weights)
%042_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%042_convolutional, %042_convolutional_bn_scale, %042_convolutional_bn_bias, %042_convolutional_bn_mean, %042_convolutional_bn_var)
%042_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%042_convolutional_bn)
%043_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%042_convolutional_lrelu, %043_convolutional_conv_weights)
%043_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%043_convolutional, %043_convolutional_bn_scale, %043_convolutional_bn_bias, %043_convolutional_bn_mean, %043_convolutional_bn_var)
%043_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%043_convolutional_bn)
%044_shortcut = Add(%043_convolutional_lrelu, %041_shortcut)
%045_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%044_shortcut, %045_convolutional_conv_weights)
%045_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%045_convolutional, %045_convolutional_bn_scale, %045_convolutional_bn_bias, %045_convolutional_bn_mean, %045_convolutional_bn_var)
%045_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%045_convolutional_bn)
%046_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%045_convolutional_lrelu, %046_convolutional_conv_weights)
%046_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%046_convolutional, %046_convolutional_bn_scale, %046_convolutional_bn_bias, %046_convolutional_bn_mean, %046_convolutional_bn_var)
%046_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%046_convolutional_bn)
%047_shortcut = Add(%046_convolutional_lrelu, %044_shortcut)
%048_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%047_shortcut, %048_convolutional_conv_weights)
%048_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%048_convolutional, %048_convolutional_bn_scale, %048_convolutional_bn_bias, %048_convolutional_bn_mean, %048_convolutional_bn_var)
%048_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%048_convolutional_bn)
%049_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%048_convolutional_lrelu, %049_convolutional_conv_weights)
%049_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%049_convolutional, %049_convolutional_bn_scale, %049_convolutional_bn_bias, %049_convolutional_bn_mean, %049_convolutional_bn_var)
%049_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%049_convolutional_bn)
%050_shortcut = Add(%049_convolutional_lrelu, %047_shortcut)
%051_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%050_shortcut, %051_convolutional_conv_weights)
%051_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%051_convolutional, %051_convolutional_bn_scale, %051_convolutional_bn_bias, %051_convolutional_bn_mean, %051_convolutional_bn_var)
%051_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%051_convolutional_bn)
%052_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%051_convolutional_lrelu, %052_convolutional_conv_weights)
%052_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%052_convolutional, %052_convolutional_bn_scale, %052_convolutional_bn_bias, %052_convolutional_bn_mean, %052_convolutional_bn_var)
%052_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%052_convolutional_bn)
%053_shortcut = Add(%052_convolutional_lrelu, %050_shortcut)
%054_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%053_shortcut, %054_convolutional_conv_weights)
%054_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%054_convolutional, %054_convolutional_bn_scale, %054_convolutional_bn_bias, %054_convolutional_bn_mean, %054_convolutional_bn_var)
%054_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%054_convolutional_bn)
%055_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%054_convolutional_lrelu, %055_convolutional_conv_weights)
%055_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%055_convolutional, %055_convolutional_bn_scale, %055_convolutional_bn_bias, %055_convolutional_bn_mean, %055_convolutional_bn_var)
%055_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%055_convolutional_bn)
%056_shortcut = Add(%055_convolutional_lrelu, %053_shortcut)
%057_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%056_shortcut, %057_convolutional_conv_weights)
%057_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%057_convolutional, %057_convolutional_bn_scale, %057_convolutional_bn_bias, %057_convolutional_bn_mean, %057_convolutional_bn_var)
%057_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%057_convolutional_bn)
%058_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%057_convolutional_lrelu, %058_convolutional_conv_weights)
%058_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%058_convolutional, %058_convolutional_bn_scale, %058_convolutional_bn_bias, %058_convolutional_bn_mean, %058_convolutional_bn_var)
%058_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%058_convolutional_bn)
%059_shortcut = Add(%058_convolutional_lrelu, %056_shortcut)
%060_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%059_shortcut, %060_convolutional_conv_weights)
%060_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%060_convolutional, %060_convolutional_bn_scale, %060_convolutional_bn_bias, %060_convolutional_bn_mean, %060_convolutional_bn_var)
%060_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%060_convolutional_bn)
%061_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%060_convolutional_lrelu, %061_convolutional_conv_weights)
%061_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%061_convolutional, %061_convolutional_bn_scale, %061_convolutional_bn_bias, %061_convolutional_bn_mean, %061_convolutional_bn_var)
%061_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%061_convolutional_bn)
%062_shortcut = Add(%061_convolutional_lrelu, %059_shortcut)
%063_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [2, 2]](%062_shortcut, %063_convolutional_conv_weights)
%063_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%063_convolutional, %063_convolutional_bn_scale, %063_convolutional_bn_bias, %063_convolutional_bn_mean, %063_convolutional_bn_var)
%063_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%063_convolutional_bn)
%064_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%063_convolutional_lrelu, %064_convolutional_conv_weights)
%064_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%064_convolutional, %064_convolutional_bn_scale, %064_convolutional_bn_bias, %064_convolutional_bn_mean, %064_convolutional_bn_var)
%064_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%064_convolutional_bn)
%065_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%064_convolutional_lrelu, %065_convolutional_conv_weights)
%065_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%065_convolutional, %065_convolutional_bn_scale, %065_convolutional_bn_bias, %065_convolutional_bn_mean, %065_convolutional_bn_var)
%065_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%065_convolutional_bn)
%066_shortcut = Add(%065_convolutional_lrelu, %063_convolutional_lrelu)
%067_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%066_shortcut, %067_convolutional_conv_weights)
%067_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%067_convolutional, %067_convolutional_bn_scale, %067_convolutional_bn_bias, %067_convolutional_bn_mean, %067_convolutional_bn_var)
%067_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%067_convolutional_bn)
%068_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%067_convolutional_lrelu, %068_convolutional_conv_weights)
%068_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%068_convolutional, %068_convolutional_bn_scale, %068_convolutional_bn_bias, %068_convolutional_bn_mean, %068_convolutional_bn_var)
%068_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%068_convolutional_bn)
%069_shortcut = Add(%068_convolutional_lrelu, %066_shortcut)
%070_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%069_shortcut, %070_convolutional_conv_weights)
%070_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%070_convolutional, %070_convolutional_bn_scale, %070_convolutional_bn_bias, %070_convolutional_bn_mean, %070_convolutional_bn_var)
%070_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%070_convolutional_bn)
%071_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%070_convolutional_lrelu, %071_convolutional_conv_weights)
%071_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%071_convolutional, %071_convolutional_bn_scale, %071_convolutional_bn_bias, %071_convolutional_bn_mean, %071_convolutional_bn_var)
%071_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%071_convolutional_bn)
%072_shortcut = Add(%071_convolutional_lrelu, %069_shortcut)
%073_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%072_shortcut, %073_convolutional_conv_weights)
%073_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%073_convolutional, %073_convolutional_bn_scale, %073_convolutional_bn_bias, %073_convolutional_bn_mean, %073_convolutional_bn_var)
%073_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%073_convolutional_bn)
%074_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%073_convolutional_lrelu, %074_convolutional_conv_weights)
%074_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%074_convolutional, %074_convolutional_bn_scale, %074_convolutional_bn_bias, %074_convolutional_bn_mean, %074_convolutional_bn_var)
%074_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%074_convolutional_bn)
%075_shortcut = Add(%074_convolutional_lrelu, %072_shortcut)
%076_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%075_shortcut, %076_convolutional_conv_weights)
%076_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%076_convolutional, %076_convolutional_bn_scale, %076_convolutional_bn_bias, %076_convolutional_bn_mean, %076_convolutional_bn_var)
%076_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%076_convolutional_bn)
%077_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%076_convolutional_lrelu, %077_convolutional_conv_weights)
%077_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%077_convolutional, %077_convolutional_bn_scale, %077_convolutional_bn_bias, %077_convolutional_bn_mean, %077_convolutional_bn_var)
%077_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%077_convolutional_bn)
%078_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%077_convolutional_lrelu, %078_convolutional_conv_weights)
%078_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%078_convolutional, %078_convolutional_bn_scale, %078_convolutional_bn_bias, %078_convolutional_bn_mean, %078_convolutional_bn_var)
%078_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%078_convolutional_bn)
%079_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%078_convolutional_lrelu, %079_convolutional_conv_weights)
%079_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%079_convolutional, %079_convolutional_bn_scale, %079_convolutional_bn_bias, %079_convolutional_bn_mean, %079_convolutional_bn_var)
%079_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%079_convolutional_bn)
%080_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%079_convolutional_lrelu, %080_convolutional_conv_weights)
%080_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%080_convolutional, %080_convolutional_bn_scale, %080_convolutional_bn_bias, %080_convolutional_bn_mean, %080_convolutional_bn_var)
%080_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%080_convolutional_bn)
%081_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%080_convolutional_lrelu, %081_convolutional_conv_weights)
%081_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%081_convolutional, %081_convolutional_bn_scale, %081_convolutional_bn_bias, %081_convolutional_bn_mean, %081_convolutional_bn_var)
%081_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%081_convolutional_bn)
%082_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%081_convolutional_lrelu, %082_convolutional_conv_weights, %082_convolutional_conv_bias)
%085_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%080_convolutional_lrelu, %085_convolutional_conv_weights)
%085_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%085_convolutional, %085_convolutional_bn_scale, %085_convolutional_bn_bias, %085_convolutional_bn_mean, %085_convolutional_bn_var)
%085_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%085_convolutional_bn)
%086_upsample = Upsample[mode = 'nearest'](%085_convolutional_lrelu, %086_upsample_scale)
%087_route = Concat[axis = 1](%086_upsample, %062_shortcut)
%088_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%087_route, %088_convolutional_conv_weights)
%088_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%088_convolutional, %088_convolutional_bn_scale, %088_convolutional_bn_bias, %088_convolutional_bn_mean, %088_convolutional_bn_var)
%088_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%088_convolutional_bn)
%089_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%088_convolutional_lrelu, %089_convolutional_conv_weights)
%089_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%089_convolutional, %089_convolutional_bn_scale, %089_convolutional_bn_bias, %089_convolutional_bn_mean, %089_convolutional_bn_var)
%089_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%089_convolutional_bn)
%090_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%089_convolutional_lrelu, %090_convolutional_conv_weights)
%090_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%090_convolutional, %090_convolutional_bn_scale, %090_convolutional_bn_bias, %090_convolutional_bn_mean, %090_convolutional_bn_var)
%090_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%090_convolutional_bn)
%091_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%090_convolutional_lrelu, %091_convolutional_conv_weights)
%091_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%091_convolutional, %091_convolutional_bn_scale, %091_convolutional_bn_bias, %091_convolutional_bn_mean, %091_convolutional_bn_var)
%091_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%091_convolutional_bn)
%092_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%091_convolutional_lrelu, %092_convolutional_conv_weights)
%092_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%092_convolutional, %092_convolutional_bn_scale, %092_convolutional_bn_bias, %092_convolutional_bn_mean, %092_convolutional_bn_var)
%092_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%092_convolutional_bn)
%093_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%092_convolutional_lrelu, %093_convolutional_conv_weights)
%093_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%093_convolutional, %093_convolutional_bn_scale, %093_convolutional_bn_bias, %093_convolutional_bn_mean, %093_convolutional_bn_var)
%093_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%093_convolutional_bn)
%094_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%093_convolutional_lrelu, %094_convolutional_conv_weights, %094_convolutional_conv_bias)
%097_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%092_convolutional_lrelu, %097_convolutional_conv_weights)
%097_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%097_convolutional, %097_convolutional_bn_scale, %097_convolutional_bn_bias, %097_convolutional_bn_mean, %097_convolutional_bn_var)
%097_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%097_convolutional_bn)
%098_upsample = Upsample[mode = 'nearest'](%097_convolutional_lrelu, %098_upsample_scale)
%099_route = Concat[axis = 1](%098_upsample, %037_shortcut)
%100_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%099_route, %100_convolutional_conv_weights)
%100_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%100_convolutional, %100_convolutional_bn_scale, %100_convolutional_bn_bias, %100_convolutional_bn_mean, %100_convolutional_bn_var)
%100_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%100_convolutional_bn)
%101_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%100_convolutional_lrelu, %101_convolutional_conv_weights)
%101_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%101_convolutional, %101_convolutional_bn_scale, %101_convolutional_bn_bias, %101_convolutional_bn_mean, %101_convolutional_bn_var)
%101_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%101_convolutional_bn)
%102_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%101_convolutional_lrelu, %102_convolutional_conv_weights)
%102_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%102_convolutional, %102_convolutional_bn_scale, %102_convolutional_bn_bias, %102_convolutional_bn_mean, %102_convolutional_bn_var)
%102_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%102_convolutional_bn)
%103_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%102_convolutional_lrelu, %103_convolutional_conv_weights)
%103_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%103_convolutional, %103_convolutional_bn_scale, %103_convolutional_bn_bias, %103_convolutional_bn_mean, %103_convolutional_bn_var)
%103_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%103_convolutional_bn)
%104_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%103_convolutional_lrelu, %104_convolutional_conv_weights)
%104_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%104_convolutional, %104_convolutional_bn_scale, %104_convolutional_bn_bias, %104_convolutional_bn_mean, %104_convolutional_bn_var)
%104_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%104_convolutional_bn)
%105_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%104_convolutional_lrelu, %105_convolutional_conv_weights)
%105_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%105_convolutional, %105_convolutional_bn_scale, %105_convolutional_bn_bias, %105_convolutional_bn_mean, %105_convolutional_bn_var)
%105_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%105_convolutional_bn)
%106_convolutional = Conv[auto_pad = 'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%105_convolutional_lrelu, %106_convolutional_conv_weights, %106_convolutional_conv_bias)
return %082_convolutional, %094_convolutional, %106_convolutional
Doesn’t mention any kind of error
Seems to be the issue with the version of the TensorRT
according to this post
I am running out of memory while trying to convert YoloV3 to TensorRT.
When I was able to convert the YoloV3 into TensorRT on Jetson Nano.
What is going wrong?
Is there a work around?
https://github.com/NVIDIA/TensorRT/issues/319
This seems to be same with every GTX 1050Ti when using YoloV3 https://devtalk.nvidia.com/default/topic/1044046/tensorrt/-tensorrt-error-network-must-have-at-least-one-output/
FWIW I just ran this sample on a V100 and saw peak memory usage of about ~1.5GB, which is less than 1050Ti’s cap of 4GB. However, I believe it is dependent on which kernels are chosen during engine building, which is dependent on the GPU / Compute Capability.
The workspace size was the same as the script you linked (1 << 28 ~= 256MB). I don’t have a 1050Ti to test on, but I’ll see if I can look into the root cause a bit more.
You might be able to try lowering the workspace size and see if that helps.
pip3 install -U protobuf
it works for me with JetsonNano
Hi ,
We recommend you to check the supported features from the below link.
You can refer below link for all the supported operators list.
For unsupported operators, you need to create a custom plugin to support the operation
