Hii all,
I am a beginner working with Jetson nano and Jetson xavier.
Recently I have implemented yolo v4 tiny on jetson nano with webcam using darknet. The model worked well and the webcam fps was nearly 4 fps.
So I have tried it using Jetson xavier so that I can increase the fps.
But surprisingly even on Jetson xavier I am getting the same 4 fps with webcam. Can anyone tell me the reason behind this and how to avoid it??
but even after changing the power mode and after using the second command iam still getting the same fps.
is there anything I need to change??
thanks in advance
