Hi, I trained Yolo V4 with resnet and mobilnetV1 succesfully, but when I change to mobilenet V2, it gives me this error:
File “/home/obaba/.cache/dazel/_dazel_obaba/e56ee0dba0ec09ac4333617b53ded644/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 209, in
File “/home/obaba/.cache/dazel/_dazel_obaba/e56ee0dba0ec09ac4333617b53ded644/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 205, in main
File “/home/obaba/.cache/dazel/_dazel_obaba/e56ee0dba0ec09ac4333617b53ded644/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 162, in run_experiment
File “/usr/local/lib/python3.6/dist-packages/keras/legacy/interfaces.py”, line 91, in wrapper
return func(*args, **kwargs)
File “/usr/local/lib/python3.6/dist-packages/keras/engine/training.py”, line 1418, in fit_generator
initial_epoch=initial_epoch)
File “/usr/local/lib/python3.6/dist-packages/keras/engine/training_generator.py”, line 217, in fit_generator
class_weight=class_weight)
File “/usr/local/lib/python3.6/dist-packages/keras/engine/training.py”, line 1217, in train_on_batch
outputs = self.train_function(ins)
File “/usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py”, line 2715, in call
return self._call(inputs)
File “/usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py”, line 2675, in _call
fetched = self._callable_fn(*array_vals)
File “/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/client/session.py”, line 1472, in call
run_metadata_ptr)
tensorflow.python.framework.errors_impl.ResourceExhaustedError: 2 root error(s) found.
(0) Resource exhausted: OOM when allocating tensor with shape[10,32,144,180] and type float on /job:localhost/replica:0/task:0/device:GPU:0 by allocator GPU_0_bfc
[[{{node yolo_conv5_6_bn_1/FusedBatchNormV3}}]]
Hint: If you want to see a list of allocated tensors when OOM happens, add report_tensor_allocations_upon_oom to RunOptions for current allocation info.
[[loss_1/add_52/_6167]]
(1) Resource exhausted: OOM when allocating tensor with shape[10,32,144,180] and type float on /job:localhost/replica:0/task:0/device:GPU:0 by allocator GPU_0_bfc
0 successful operations.
0 derived errors ignored.
File “/usr/local/bin/yolo_v4”, line 8, in
sys.exit(main())
File “/home/obaba/.cache/dazel/_dazel_obaba/e56ee0dba0ec09ac4333617b53ded644/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/entrypoint/yolo_v4.py”, line 12, in main
File “/home/obaba/.cache/dazel/_dazel_obaba/e56ee0dba0ec09ac4333617b53ded644/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/entrypoint/entrypoint.py”, line 286, in launch_job
AssertionError: Process run failed.
How shouil I fix this? Thanks!
