Description
I was convert wts to trt, model building successfully,but still have error.
Please give me help,thanks!
Environment
System: AGX Orin
TensorRT Version: 8.5.2.2
CUDA Version: 11.4
CUDNN Version: 8.6
ubuntu: 20.04
System: AGX Orin
CUDA Version: 11.4
CUDNN Version: 8.6
ubuntu: 20.04
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
But my model does not convert to onnx,convert process was pth->wts->trt
Since you already converted the model into a TensorRT engine, could you check if it can work with trtexec?
$ /usr/src/tensorrt/bin/trtexec --loadEngine=[file] --verbose
