I updated the createYoloNetwork function code for Yolo.cpp file , in order to parse yoloV3-SPP network.
ObjectDetector-yolo could parse yoloV3-SPP network successfully after updated this code,but it has a bad accurate compared with darknet result, I’m very confused for this result.
This problem block my project seriously , I hope you can help me to solve it quickly.
Updated code please see below content: updated (else if (m_configBlocks.at(i).at(“type”) == “route”) and else if (m_configBlocks.at(i).at(“type”) == “maxpool”))
` else if (m_configBlocks.at(i).at(“type”) == “route”)
int cont=0;
int idx[6];
int lac[6];
size_t found = m_configBlocks.at(i).at(“layers”).find(“,”);
if (found != std::string::npos)
size_t pos;
int size=m_configBlocks.at(i).at(“layers”).size();
for(int j=0; j<size; j++)
pos= m_configBlocks.at(i).at(“layers”).find(“,”,j);
if(pos!= std::string::npos)
{YoloCPP.log (25.0 KB) yolov3-spp3 CFG.log (8.7 KB)
if(cont==0)
lac[cont]=0;
idx[cont] = std::stoi(trim(m_configBlocks.at(i).at("layers").substr(lac[cont], pos)));
printf("cont-idx[%d]=%d \n",cont,idx[cont]);
cont=cont+1;
lac[cont]=pos+1;
//std::string s= m_configBlocks.at(i).at("layers").substr(i,pos-i);
//result.push_back(s);
j=pos+1;
printf("pos=%d \n",pos);
else{
idx[cont] = std::stoi(trim(m_configBlocks.at(i).at("layers").substr(lac[cont])));
cont=cont+1;
break;
//int idx1 = std::stoi(trim(m_configBlocks.at(i).at("layers").substr(0, found)));
// int idx2 = std::stoi(trim(m_configBlocks.at(i).at("layers").substr(found + 1)));
//int idx3 = std::stoi(trim(m_configBlocks.at(i).at("layers").substr(found + 2)));
//int idx4 = std::stoi(trim(m_configBlocks.at(i).at("layers").substr(found + 3)));
//int idx3=-5;
//int idx4=-6;
for(int j=0; j<cont; j++)
printf("idx[%d]=%d \n",j,idx[j]);
if (idx[j] < 0)
idx[j] = tensorOutputs.size() + idx[j];
assert(idx[j] < static_cast<int>(tensorOutputs.size()) && idx[j] >= 0);
//printLayerInfo(idx1, idx2);
if (idx1 < 0)
idx1 = tensorOutputs.size() + idx1;
if (idx2 < 0)
idx2 = tensorOutputs.size() + idx2;
if (idx3 < 0)
idx3 = tensorOutputs.size() + idx3;
if (idx4 < 0)
idx4 = tensorOutputs.size() + idx4;
assert(idx1 < static_cast(tensorOutputs.size()) && idx1 >= 0);
assert(idx2 < static_cast(tensorOutputs.size()) && idx2 >= 0);
assert(idx3 < static_cast(tensorOutputs.size()) && idx3 >= 0);
assert(idx4 < static_cast(tensorOutputs.size()) && idx4 >= 0);
nvinfer1::ITensor* concatInputs
= reinterpret_castnvinfer1::ITensor**(malloc(sizeof(nvinfer1::ITensor*) * cont));
printf(“cont=%d \n”,cont);
concatInputs[j] = tensorOutputs[idx[j]];
// concatInputs[0] = tensorOutputs[idx1];
// concatInputs[1] = tensorOutputs[idx2];
// concatInputs[2] = tensorOutputs[idx3];
// concatInputs[3] = tensorOutputs[idx4];
nvinfer1::IConcatenationLayer* concat
= network->addConcatenation(concatInputs, cont);
assert(concat != nullptr);
std::string concatLayerName = “route_” + std::to_string(i - 1);
concat->setName(concatLayerName.c_str());
// concatenate along the channel dimension
concat->setAxis(0);
previous = concat->getOutput(0);
assert(previous != nullptr);
std::string outputVol = dimsToString(previous->getDimensions());
// set the output volume depth
channels= getNumChannels(tensorOutputs[idx[0]]);
for(int j=1; j<cont; j++)
channels=channels+getNumChannels(tensorOutputs[idx[j]]);
// channels
// = getNumChannels(tensorOutputs[idx1]) + getNumChannels(tensorOutputs[idx2]) + getNumChannels(tensorOutputs[idx3]) + getNumChannels(tensorOutputs[idx4]);
tensorOutputs.push_back(concat->getOutput(0));
printLayerInfo(layerIndex, "route", " -", outputVol,
std::to_string(weightPtr));
else
int idx = std::stoi(trim(m_configBlocks.at(i).at("layers")));
if (idx < 0)
idx = tensorOutputs.size() + idx;
assert(idx < static_cast<int>(tensorOutputs.size()) && idx >= 0);
previous = tensorOutputs[idx];
channels = getNumChannels(tensorOutputs[idx]);
tensorOutputs.push_back(tensorOutputs[idx]);
else if (m_configBlocks.at(i).at("type") == "upsample")
std::string inputVol = dimsToString(previous->getDimensions());
nvinfer1::ILayer* out = netAddUpsample(i - 1, m_configBlocks[i], weights, trtWeights,
channels, previous, network);
previous = out->getOutput(0);
tensorOutputs.push_back(out->getOutput(0));
printLayerInfo(layerIndex, "upsample", inputVol, outputVol, " -");
else if (m_configBlocks.at(i).at("type") == "maxpool")
// Add same padding layers
if (m_configBlocks.at(i).at("size") == "2" && m_configBlocks.at(i).at("stride") == "1")
m_TinyMaxpoolPaddingFormula->addSamePaddingLayer("maxpool_" + std::to_string(i));
if (m_configBlocks.at(i).at("size") == "5" && m_configBlocks.at(i).at("stride") == "1")
if (m_configBlocks.at(i).at("size") == "9" && m_configBlocks.at(i).at("stride") == "1")
if (m_configBlocks.at(i).at("size") == "13" && m_configBlocks.at(i).at("stride") == "1")
nvinfer1::ILayer* out = netAddMaxpool(i, m_configBlocks.at(i), previous, network);
printLayerInfo(layerIndex, "maxpool", inputVol, outputVol, std::to_string(weightPtr));
else
std::cout << "Unsupported layer type --> \"" << m_configBlocks.at(i).at("type") << "\""
<< std::endl;
assert(0);
