Hi all,
I’m attempting to follow the instructions for the tensorrt sample: https://docs.nvidia.com/deeplearning/sdk/tensorrt-developer-guide/index.html#yolov3_onnx
I have installed onnx-tensorrt - does this error likely indicate that something is wrong with that installation?
Layer of type yolo not supported, skipping ONNX node generation.
graph YOLOv3-608 (
%000_net[FLOAT, 64x3x608x608]
) initializers (
%001_convolutional_bn_scale[FLOAT, 32]
%001_convolutional_bn_bias[FLOAT, 32]
%105_convolutional = Conv[auto_pad = u'SAME_LOWER', dilations = [1, 1], kernel_shape = [3, 3], strides = [1, 1]](%104_convolutional_lrelu, %105_convolutional_conv_weights)
%105_convolutional_bn = BatchNormalization[epsilon = 9.99999974737875e-06, momentum = 0.990000009536743](%105_convolutional, %105_convolutional_bn_scale, %105_convolutional_bn_bias, %105_convolutional_bn_mean, %105_convolutional_bn_var)
%105_convolutional_lrelu = LeakyRelu[alpha = 0.100000001490116](%105_convolutional_bn)
%106_convolutional = Conv[auto_pad = u'SAME_LOWER', dilations = [1, 1], kernel_shape = [1, 1], strides = [1, 1]](%105_convolutional_lrelu, %106_convolutional_conv_weights, %106_convolutional_conv_bias)
return %082_convolutional, %094_convolutional, %106_convolutional
File "yolov3_to_onnx.py", line 761, in <module>
main()
File "yolov3_to_onnx.py", line 754, in main
onnx.checker.check_model(yolov3_model_def)
File "/home/luke/.local/lib/python2.7/site-packages/onnx/checker.py", line 77, in check_model
C.check_model(model.SerializeToString())
onnx.onnx_cpp2py_export.checker.ValidationError: Input index 3 must be set to consumed for operator BatchNormalization
==> Context: Bad node spec: input: "001_convolutional" input: "001_convolutional_bn_scale" input: "001_convolutional_bn_bias" input: "001_convolutional_bn_mean" input: "001_convolutional_bn_var" output: "001_convolutional_bn" name: "001_convolutional_bn" op_type: "BatchNormalization" attribute { name: "epsilon" f: 1e-05 type: FLOAT } attribute { name: "momentum" f: 0.99 type: FLOAT }
