Yolov3 train fails with rmsprop optimizer
Here is my spec file to train yolov3 with rmsprop optimizer. But, I get following error:
final_spec.txt (2.0 KB)
INFO: beta2
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/scripts/train.py", line 145, in <module>
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/utils.py", line 707, in return_func
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/utils.py", line 695, in return_func
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/scripts/train.py", line 141, in main
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/scripts/train.py", line 126, in main
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/scripts/train.py", line 72, in run_experiment
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/models/utils.py", line 59, in build_training_pipeline
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/models/yolov3_model.py", line 187, in build_optimizer
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/utils.py", line 614, in build_optimizer_from_config
AttributeError: beta2
Using TensorFlow backend.
For rmsprop, please set
  • beta2 , It should be within (0, 1).
  • momentum , It should be >=0.
  • epsilon > 0 , It should be greater than 0.
I set beta2 parameter. But I got the following error:
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/scripts/train.py", line 63, in run_experiment
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v3/utils/spec_loader.py", line 20, in load_experiment_spec
File "/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py", line 725, in Merge
allow_unknown_field=allow_unknown_field)
File "/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py", line 793, in MergeLines
return parser.MergeLines(lines, message)
File "/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py", line 818, in MergeLines
self._ParseOrMerge(lines, message)
File "/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py", line 837, in _ParseOrMerge
self._MergeField(tokenizer, message)
File "/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py", line 967, in _MergeField
merger(tokenizer, message, field)
File "/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py", line 1042, in _MergeMessageField
self._MergeField(tokenizer, sub_message)
File "/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py", line 934, in _MergeField
(message_descriptor.full_name, name))
google.protobuf.text_format.ParseError: 37:7 : Message type "RMSpropOptimizerConfig" has no field named "beta2".
Please use below.
  • rho , It should be within (0, 1).
