• Hardware (T4/V100/Xavier/Nano/etc)
RTX 2070
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc)
YoloV4_tiny
**• TLT Version
nvidia/tao/tao-toolkit-tf:
v3.21.11-tf1.15.5-py3
**• Training spec file:
random_seed: 42
yolov4_config {
big_anchor_shape: “[(260.69, 172.35), (125.91, 81.47), (72.27, 42.42)]”
mid_anchor_shape: “[(30.80, 71.40), (38.97, 26.86), (18.88, 17.11)]”
box_matching_iou: 0.25
matching_neutral_box_iou: 0.5
arch: “cspdarknet_tiny”
loss_loc_weight: 1.0
loss_neg_obj_weights: 1.0
loss_class_weights: 1.0
label_smoothing: 0.0
big_grid_xy_extend: 0.05
mid_grid_xy_extend: 0.05
freeze_bn: false
#freeze_blocks: 0
force_relu: false
training_config {
batch_size_per_gpu: 8
num_epochs: 80
enable_qat: false
checkpoint_interval: 10
learning_rate {
soft_start_cosine_annealing_schedule {
min_learning_rate: 1e-7
max_learning_rate: 1e-4
soft_start: 0.3
regularizer {
type: L1
weight: 3e-5
optimizer {
adam {
epsilon: 1e-7
beta1: 0.9
beta2: 0.999
amsgrad: false
eval_config {
average_precision_mode: SAMPLE
batch_size: 8
matching_iou_threshold: 0.5
nms_config {
confidence_threshold: 0.001
clustering_iou_threshold: 0.5
force_on_cpu: true
top_k: 200
augmentation_config {
hue: 0.1
saturation: 1.5
exposure:1.5
vertical_flip:0
horizontal_flip: 0.5
jitter: 0.3
output_width: 416
output_height: 416
output_channel: 3
randomize_input_shape_period: 10
mosaic_prob: 0.5
mosaic_min_ratio:0.2
dataset_config {
data_sources: {
label_directory_path: “/workspace/tao-experiments/data/training/label”
image_directory_path: “/workspace/tao-experiments/data/training/image”
include_difficult_in_training: true
target_class_mapping {
key: “eye”
value: “eye”
z
validation_data_sources: {
label_directory_path: “/workspace/tao-experiments/data/val/label”
image_directory_path: “/workspace/tao-experiments/data/val/image”
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
Hi. I am trying to train Yolo_v4_tiny for (416,416,1) images. I also tried outputchannel with 1 as the jpg color is black ad white. but receive the following error…
I first run the docker, than write the command to train… it is as below
What is that “YOLOv3DatasetConfig” has no field named “z”.
docker run --gpus all -it -v /workspace/tao-experiments/:/workspace/tao-experiments -p 8888:8888 --entrypoint “” nvcr.io/nvidia/tao/tao-toolkit-tf:v3.22.05-tf1.15.4-py3 /bin/bash
root@ceddc7dd5ab9:/workspace# yolo_v4 train --gpus 1 --use_amp -e /workspace/tao-experiments/specs/YOLOv4-tiny.txt -r /workspace/tao-experiments/results -k “key”
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
/usr/local/lib/python3.6/dist-packages/requests/init.py:91: RequestsDependencyWarning: urllib3 (1.26.5) or chardet (3.0.4) doesn’t match a supported version!
RequestsDependencyWarning)
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:42: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
WARNING: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:42: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:45: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
WARNING: From /root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:45: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
INFO: Log file already exists at /workspace/tao-experiments/results/status.json
INFO: 78:1 : Message type “YOLOv3DatasetConfig” has no field named “z”.
File “/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 145, in
File “/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/utils.py”, line 707, in return_func
File “/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/common/utils.py”, line 695, in return_func
File “/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 141, in main
File “/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 126, in main
File “/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py”, line 63, in run_experiment
File “/root/.cache/bazel/_bazel_root/b770f990bb7b9e2db5771981fb3a38b4/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/utils/spec_loader.py”, line 20, in load_experiment_spec
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 725, in Merge
allow_unknown_field=allow_unknown_field)
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 793, in MergeLines
return parser.MergeLines(lines, message)
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 818, in MergeLines
self._ParseOrMerge(lines, message)
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 837, in _ParseOrMerge
self._MergeField(tokenizer, message)
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 967, in _MergeField
merger(tokenizer, message, field)
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 1042, in _MergeMessageField
self._MergeField(tokenizer, sub_message)
File “/usr/local/lib/python3.6/dist-packages/google/protobuf/text_format.py”, line 934, in _MergeField
(message_descriptor.full_name, name))
google.protobuf.text_format.ParseError: 78:1 : Message type “YOLOv3DatasetConfig” has no field named “z”.
root@ceddc7dd5ab9:/workspace# ^C
