How to train Yolov4 for different input size? Are pretrained model weights available for the different sizes?
Just set different input size via
output_width: xxx
output_height: xxx
Make sure meet YOLOv4 — TAO Toolkit 3.21.11 documentation
Hi @Morganh
I am stuck at this point after training 8k images. Could you please help me with the following:
- do all images need to be of the same size? if yes,
- can my custom dataset size be different to the original kitti dataset sizes e.g.: something like 1920 x 1080 instead of 1248 x 384 (or 348)?
For yolov4 network, it is not needed.
Sure, it can.
Thanks Morganh,
I was assuming that the high loss values that I am getting are because of the image sizing issues. However, since you confirmed that it was not the case, I ran the training few more times and still getting the same loss values. for first epoch, the loss value stands at around 24 million and it reduces to few thousands by (last) 80th epoch.
Tried running the original kitti dataset without any changes and still result is the same.
We are running Yolov4 with Resnet18 - default config file, no changes at all. We are running it on AWS with 4 GPUs. Included below:
random_seed: 42
yolov4_config {
big_anchor_shape: "[(114.94, 60.67), (159.06, 114.59), (297.59, 176.38)]"
mid_anchor_shape: "[(42.99, 31.91), (79.57, 31.75), (56.80, 56.93)]"
small_anchor_shape: "[(15.60, 13.88), (30.25, 20.25), (20.67, 49.63)]"
box_matching_iou: 0.25
matching_neutral_box_iou: 0.5
arch: "resnet"
nlayers: 18
arch_conv_blocks: 2
loss_loc_weight: 0.8
loss_neg_obj_weights: 100.0
loss_class_weights: 0.5
label_smoothing: 0.0
big_grid_xy_extend: 0.05
mid_grid_xy_extend: 0.1
small_grid_xy_extend: 0.2
freeze_bn: false
#freeze_blocks: 0
force_relu: false
training_config {
batch_size_per_gpu: 8
num_epochs: 80
enable_qat: false
checkpoint_interval: 10
learning_rate {
soft_start_cosine_annealing_schedule {
min_learning_rate: 1e-7
max_learning_rate: 1e-4
soft_start: 0.3
regularizer {
type: L1
weight: 3e-5
optimizer {
adam {
epsilon: 1e-7
beta1: 0.9
beta2: 0.999
amsgrad: false
pretrain_model_path: "/workspace/tao-experiments/yolo_v4/pretrained_resnet18/pretrained_object_detection_vresnet18/resnet_18.hdf5"
eval_config {
average_precision_mode: SAMPLE
batch_size: 8
matching_iou_threshold: 0.5
nms_config {
confidence_threshold: 0.001
clustering_iou_threshold: 0.5
force_on_cpu: true
top_k: 200
augmentation_config {
hue: 0.1
saturation: 1.5
exposure:1.5
vertical_flip:0
horizontal_flip: 0.5
jitter: 0.3
output_width: 1248
output_height: 384
output_channel: 3
randomize_input_shape_period: 0
mosaic_prob: 0.5
mosaic_min_ratio:0.2
dataset_config {
data_sources: {
tfrecords_path: "/workspace/tao-experiments/data/training/tfrecords/train*"
image_directory_path: "/workspace/tao-experiments/data/training"
include_difficult_in_training: true
image_extension: "png"
target_class_mapping {
key: "car"
value: "car"
key: "pedestrian"
value: "pedestrian"
key: "cyclist"
value: "cyclist"
key: "van"
value: "car"
key: "person_sitting"
value: "pedestrian"
validation_data_sources: {
tfrecords_path: "/workspace/tao-experiments/data/val/tfrecords/val*"
image_directory_path: "/workspace/tao-experiments/data/val"
and here is the training part:
To run with multigpu, please change --gpus based on the number of available GPUs in your machine.
2022-02-19 06:58:19,493 [INFO] root: Registry: ['nvcr.io']
2022-02-19 06:58:19,572 [INFO] tlt.components.instance_handler.local_instance: Running command in container: nvcr.io/nvidia/tao/tao-toolkit-tf:v3.21.11-tf1.15.5-py3
2022-02-19 06:58:19,582 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the "user":"UID:GID" in the
DockerOptions portion of the "/home/ubuntu/.tao_mounts.json" file. You can obtain your
users UID and GID by using the "id -u" and "id -g" commands on the
terminal.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:40: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
2022-02-19 06:58:27,863 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:40: The name tf.ConfigProto is deprecated. Please use tf.compat.v1.ConfigProto instead.
WARNING:tensorflow:From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:43: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2022-02-19 06:58:27,863 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:43: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
2022-02-19 06:58:27,864 [WARNING] tensorflow: From /root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/yolo_v4/scripts/train.py:43: The name tf.Session is deprecated. Please use tf.compat.v1.Session instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2022-02-19 06:58:29,211 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2022-02-19 06:58:29,217 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2022-02-19 06:58:29,219 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2022-02-19 06:58:29,228 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2022-02-19 06:58:29,230 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2022-02-19 06:58:29,234 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2022-02-19 06:58:29,236 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2022-02-19 06:58:29,236 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2022-02-19 06:58:29,237 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2022-02-19 06:58:29,243 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2022-02-19 06:58:29,246 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:153: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
2022-02-19 06:58:29,252 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:517: The name tf.placeholder is deprecated. Please use tf.compat.v1.placeholder instead.
2022-02-19 06:58:29,253 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:4138: The name tf.random_uniform is deprecated. Please use tf.random.uniform instead.
2022-02-19 06:58:29,260 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2022-02-19 06:58:29,262 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
2022-02-19 06:58:29,278 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:1834: The name tf.nn.fused_batch_norm is deprecated. Please use tf.compat.v1.nn.fused_batch_norm instead.
WARNING:tensorflow:From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
2022-02-19 06:58:30,082 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
2022-02-19 06:58:30,102 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
2022-02-19 06:58:30,109 [WARNING] tensorflow: From /opt/nvidia/third_party/keras/tensorflow_backend.py:183: The name tf.nn.max_pool is deprecated. Please use tf.nn.max_pool2d instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
2022-02-19 06:58:30,403 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
2022-02-19 06:58:30,420 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
2022-02-19 06:58:30,425 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
2022-02-19 06:58:30,434 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:2018: The name tf.image.resize_nearest_neighbor is deprecated. Please use tf.compat.v1.image.resize_nearest_neighbor instead.
2022-02-19 06:58:31,804 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Serial augmentation enabled = False
2022-02-19 06:58:31,804 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Pseudo sharding enabled = False
2022-02-19 06:58:31,805 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Max Image Dimensions (all sources): (0, 0)
2022-02-19 06:58:31,805 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: number of cpus: 32, io threads: 64, compute threads: 32, buffered batches: -1
2022-02-19 06:58:31,805 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: total dataset size 6733, number of sources: 1, batch size per gpu: 20, steps: 337
2022-02-19 06:58:31,852 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Serial augmentation enabled = False
2022-02-19 06:58:31,852 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Pseudo sharding enabled = False
2022-02-19 06:58:31,852 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Max Image Dimensions (all sources): (0, 0)
2022-02-19 06:58:31,852 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: number of cpus: 32, io threads: 64, compute threads: 32, buffered batches: -1
2022-02-19 06:58:31,852 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: total dataset size 6733, number of sources: 1, batch size per gpu: 20, steps: 337
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
2022-02-19 06:58:31,858 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
2022-02-19 06:58:31,878 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Serial augmentation enabled = False
2022-02-19 06:58:31,878 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Pseudo sharding enabled = False
2022-02-19 06:58:31,878 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Max Image Dimensions (all sources): (0, 0)
2022-02-19 06:58:31,879 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: number of cpus: 32, io threads: 64, compute threads: 32, buffered batches: -1
2022-02-19 06:58:31,879 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Serial augmentation enabled = False
2022-02-19 06:58:31,879 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: total dataset size 6733, number of sources: 1, batch size per gpu: 20, steps: 337
2022-02-19 06:58:31,879 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Pseudo sharding enabled = False
2022-02-19 06:58:31,879 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Max Image Dimensions (all sources): (0, 0)
2022-02-19 06:58:31,900 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
WARNING:tensorflow:Entity <bound method YOLOv3TFRecordsParser.__call_ of <iva.yolo_v3.data_loader.yolo_v3_data_loader.YOLOv3TFRecordsParser object at 0x7f5e086921d0>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method YOLOv3TFRecordsParser.__call_ of <iva.yolo_v3.data_loader.yolo_v3_data_loader.YOLOv3TFRecordsParser object at 0x7f5e086921d0>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-02-19 06:58:31,908 [WARNING] tensorflow: Entity <bound method YOLOv3TFRecordsParser.__call_ of <iva.yolo_v3.data_loader.yolo_v3_data_loader.YOLOv3TFRecordsParser object at 0x7f5e086921d0>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method YOLOv3TFRecordsParser.__call_ of <iva.yolo_v3.data_loader.yolo_v3_data_loader.YOLOv3TFRecordsParser object at 0x7f5e086921d0>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-02-19 06:58:31,926 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
2022-02-19 06:58:31,934 [INFO] iva.detectnet_v2.dataloader.default_dataloader: Bounding box coordinates were detected in the input specification! Bboxes will be automatically converted to polygon coordinates.
WARNING:tensorflow:Entity <bound method YOLOv3TFRecordsParser.__call_ of <iva.yolo_v3.data_loader.yolo_v3_data_loader.YOLOv3TFRecordsParser object at 0x7f22c43d5208>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method YOLOv3TFRecordsParser.__call_ of <iva.yolo_v3.data_loader.yolo_v3_data_loader.YOLOv3TFRecordsParser object at 0x7f22c43d5208>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-02-19 06:58:31,948 [WARNING] tensorflow: Entity <bound method YOLOv3TFRecordsParser.__call_ of <iva.yolo_v3.data_loader.yolo_v3_data_loader.YOLOv3TFRecordsParser object at 0x7f22c43d5208>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method YOLOv3TFRecordsParser.__call_ of <iva.yolo_v3.data_loader.yolo_v3_data_loader.YOLOv3TFRecordsParser object at 0x7f22c43d5208>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
WARNING:tensorflow:Entity <bound method YOLOv3TFRecordsParser.__call__ of <iva.yolo_v3.data_loader.yolo_v3_data_loader.YOLOv3TFRec
I believe it is 3.21.08 as shown on this page:
https://docs.nvidia.com/tao/tao-toolkit/text/running_in_cloud/overview.html
We are running it on AWS using Nvidia AMI AWS Marketplace: NVIDIA Deep Learning AMI
How did you setup the environment for running tao on AWS?
BTW, could you share the info of “$ tao info --verbose”?
Ok, it is v3.21.11-tf1.15.5-py3:
The environment is ready-to-use AMI from Nvidia. We launched the instance and followed the steps here: Running TAO Toolkit on an AWS VM — TAO Toolkit 3.21.11 documentation
For 3.21.11 version, please change above to
loss_loc_weight: 1.0
loss_neg_obj_weights: 1.0
loss_class_weights: 1.0
BTW, it is normal to see high loss value in the beginning. Please focus on mAP in the end.
Thank you! Sorry for circling back on the question of image sizing. I have one more doubt regarding that. For Yolo training, are there any specific sizing rules? e.g.: all images to be same size / same ratio / similar sizing? Currently we are taking our Yolo dataset, convert all label txt files to Kitti and converting all images to PNG from JPEG. Is this about right or should we be taking any other steps before we bring the dataset over?
For yolo_v4, you need not do any resizing offline. And also it does not need the same resolution training images. But please make sure meet the requirement mentioned in YOLOv4 — TAO Toolkit 3.21.11 documentation
I just had another read of the document. Looks like we will need to make sure that all our image sizes are in multiples of 32 and probably also work on anchor_shape using kmeans command. These two things were not correctly defined. Thank you for pointing me in the right direction.
For anchors shapes, I think you can refer to the setting in the spec files of official released jupyter notebook.
Do you mean we can use these as is?
Yes for public KITTI dataset.
thanks again. For a custom dataset, the anchor_shapes generator asks me to enter input image width and height. Since all my images are different w and h, what should I enter for these variables?
For your case, please try to resize the images to the same resolution , and also resize the labels accordingly. Then run kmeans against the new images and new labels.
Thanks, that provides the clarity. In terms of the output image size, can I use this same size, say, 1920w x 1024h? Or does output image size need to be 1248w x 384h?
It depends on your target. If you want to train a 960x544 model, then please use above way to generate anchor shapes. And also set output_width: 960 and output_height: 544
