• Hardware Platform (Jetson / GPU) : NVIDIA Corporation GA106 [Geforce RTX 3050] • DeepStream Version: 6.2 • JetPack Version (valid for Jetson only) • TensorRT Version: with SDK • NVIDIA GPU Driver Version (valid for GPU only): 525.85.12
*• Cuda Version: 11.8 • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
I want to int8 calibrate yolov4 models with my GPU. Can someone please suggest step by step process for the same.
Please make sure you know about your model and set the gst-nvinfer configuration correctly. You can refer to the sample NVIDIA-AI-IOT/yolo_deepstream: yolo model qat and deploy with deepstream&tensorrt (github.com), since there may be some differences between your model and the model in our sample, please modify the corresponding customization parts according to your model.
