Yolov4 not working in deepstream app?
In host PC, I used tlt-converter outside the docker.
Yes both fp16 and fp32 generated successfully on host PC.
Yes in jetson both (fp16, fp32) can not generated.
Which Jetpack version did you install? You are running in Nano, right?
Can you run following command and share the result too?
$ dpkg -l |grep cuda
$ uname -a
The jet-pack version is 4.4, I am using jetson nano (4GB)
ii cuda-command-line-tools-10-2 10.2.89-1 arm64 CUDA command-line tools
ii cuda-compiler-10-2 10.2.89-1 arm64 CUDA compiler
ii cuda-cudart-10-2 10.2.89-1 arm64 CUDA Runtime native Libraries
ii cuda-cudart-dev-10-2 10.2.89-1 arm64 CUDA Runtime native dev links, headers
ii cuda-cufft-10-2 10.2.89-1 arm64 CUFFT native runtime libraries
ii cuda-cufft-dev-10-2 10.2.89-1 arm64 CUFFT native dev links, headers
ii cuda-cuobjdump-10-2 10.2.89-1 arm64 CUDA cuobjdump
ii cuda-cupti-10-2 10.2.89-1 arm64 CUDA profiling tools runtime libs.
ii cuda-cupti-dev-10-2 10.2.89-1 arm64 CUDA profiling tools interface.
ii cuda-curand-10-2 10.2.89-1 arm64 CURAND native runtime libraries
ii cuda-curand-dev-10-2 10.2.89-1 arm64 CURAND native dev links, headers
ii cuda-cusolver-10-2 10.2.89-1 arm64 CUDA solver native runtime libraries
ii cuda-cusolver-dev-10-2 10.2.89-1 arm64 CUDA solver native dev links, headers
ii cuda-cusparse-10-2 10.2.89-1 arm64 CUSPARSE native runtime libraries
ii cuda-cusparse-dev-10-2 10.2.89-1 arm64 CUSPARSE native dev links, headers
ii cuda-documentation-10-2 10.2.89-1 arm64 CUDA documentation
ii cuda-driver-dev-10-2 10.2.89-1 arm64 CUDA Driver native dev stub library
ii cuda-gdb-10-2 10.2.89-1 arm64 CUDA-GDB
ii cuda-libraries-10-2 10.2.89-1 arm64 CUDA Libraries 10.2 meta-package
ii cuda-libraries-dev-10-2 10.2.89-1 arm64 CUDA Libraries 10.2 development meta-package
ii cuda-license-10-2 10.2.89-1 arm64 CUDA licenses
ii cuda-memcheck-10-2 10.2.89-1 arm64 CUDA-MEMCHECK
ii cuda-misc-headers-10-2 10.2.89-1 arm64 CUDA miscellaneous headers
ii cuda-npp-10-2 10.2.89-1 arm64 NPP native runtime libraries
ii cuda-npp-dev-10-2 10.2.89-1 arm64 NPP native dev links, headers
ii cuda-nvcc-10-2 10.2.89-1 arm64 CUDA nvcc
ii cuda-nvdisasm-10-2 10.2.89-1 arm64 CUDA disassembler
ii cuda-nvgraph-10-2 10.2.89-1 arm64 NVGRAPH native runtime libraries
ii cuda-nvgraph-dev-10-2 10.2.89-1 arm64 NVGRAPH native dev links, headers
ii cuda-nvml-dev-10-2 10.2.89-1 arm64 NVML native dev links, headers
ii cuda-nvprof-10-2 10.2.89-1 arm64 CUDA Profiler tools
ii cuda-nvprune-10-2 10.2.89-1 arm64 CUDA nvprune
ii cuda-nvrtc-10-2 10.2.89-1 arm64 NVRTC native runtime libraries
ii cuda-nvrtc-dev-10-2 10.2.89-1 arm64 NVRTC native dev links, headers
ii cuda-nvtx-10-2 10.2.89-1 arm64 NVIDIA Tools Extension
ii cuda-repo-l4t-10-2-local-10.2.89 1.0-1 arm64 cuda repository configuration files
ii cuda-samples-10-2 10.2.89-1 arm64 CUDA example applications
ii cuda-toolkit-10-2 10.2.89-1 arm64 CUDA Toolkit 10.2 meta-package
ii cuda-tools-10-2 10.2.89-1 arm64 CUDA Tools meta-package
ii graphsurgeon-tf 7.1.3-1+cuda10.2 arm64 GraphSurgeon for TensorRT package
ii libcudnn8 8.0.0.180-1+cuda10.2 arm64 cuDNN runtime libraries
ii libcudnn8-dev 8.0.0.180-1+cuda10.2 arm64 cuDNN development libraries and headers
ii libcudnn8-doc 8.0.0.180-1+cuda10.2 arm64 cuDNN documents and samples
ii libnvinfer-bin 7.1.3-1+cuda10.2 arm64 TensorRT binaries
ii libnvinfer-dev 7.1.3-1+cuda10.2 arm64 TensorRT development libraries and headers
ii libnvinfer-doc 7.1.3-1+cuda10.2 all TensorRT documentation
ii libnvinfer-plugin-dev 7.1.3-1+cuda10.2 arm64 TensorRT plugin libraries
ii libnvinfer-plugin7 7.1.3-1+cuda10.2 arm64 TensorRT plugin libraries
ii libnvinfer-samples 7.1.3-1+cuda10.2 all TensorRT samples
ii libnvinfer7 7.1.3-1+cuda10.2 arm64 TensorRT runtime libraries
ii libnvonnxparsers-dev 7.1.3-1+cuda10.2 arm64 TensorRT ONNX libraries
ii libnvonnxparsers7 7.1.3-1+cuda10.2 arm64 TensorRT ONNX libraries
ii libnvparsers-dev 7.1.3-1+cuda10.2 arm64 TensorRT parsers libraries
ii libnvparsers7 7.1.3-1+cuda10.2 arm64 TensorRT parsers libraries
ii nvidia-container-csv-cuda 10.2.89-1 arm64 Jetpack CUDA CSV file
ii nvidia-container-csv-cudnn 8.0.0.180-1+cuda10.2 arm64 Jetpack CUDNN CSV file
ii nvidia-container-csv-tensorrt 7.1.3.0-1+cuda10.2 arm64 Jetpack TensorRT CSV file
ii nvidia-l4t-cuda 32.5.1-20210519110732 arm64 NVIDIA CUDA Package
ii python-libnvinfer 7.1.3-1+cuda10.2 arm64 Python bindings for TensorRT
ii python-libnvinfer-dev 7.1.3-1+cuda10.2 arm64 Python development package for TensorRT
ii python3-libnvinfer 7.1.3-1+cuda10.2 arm64 Python 3 bindings for TensorRT
ii python3-libnvinfer-dev 7.1.3-1+cuda10.2 arm64 Python 3 development package for TensorRT
ii tensorrt 7.1.3.0-1+cuda10.2 arm64 Meta package of TensorRT
ii uff-converter-tf 7.1.3-1+cuda10.2 arm64 UFF converter for TensorRT package
$ uname -a
Linux facit-desktop 4.9.201-tegra #1 SMP PREEMPT Wed May 5 09:31:36 PDT 2021 aarch64 aarch64 aarch64 GNU/Linux
Did you ever build TRT OSS plugin ? See GitHub - NVIDIA-AI-IOT/deepstream_tlt_apps: Sample apps to demonstrate how to deploy models trained with TLT on DeepStream
Can you show the result of
$ ls -l /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so*
No I have not build TRT OSS Plugin, for deepstream-tlt-apps
lrwxrwxrwx 1 root root 26 جون 6 2020 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so → libnvinfer_plugin.so.7.1.3
lrwxrwxrwx 1 root root 26 جون 6 2020 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.7 → libnvinfer_plugin.so.7.1.3
-rw-r–r-- 1 root root 5630344 جون 6 2020 /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.7.1.3
Please backup the original libnvinfer_plugin.so.7.1.3 and then follow deepstream_tlt_apps/TRT-OSS/Jetson at master · NVIDIA-AI-IOT/deepstream_tlt_apps · GitHub to generate the new plugin and replace.
sudo mv /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.7.1.3   ${HOME}/libnvinfer_plugin.so.7.1.3.bak
sudo cp `pwd`/out/libnvinfer_plugin.so.7.m.n  /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.7.1.3
sudo ldconfig
