Anyone have any idea about Yolov4 tiny model with batch size 1.
I refered this Yolov4 repo Here to generate onnx file. By default, I had batch size 64 in my cfg. It took a while to build the engine. And then inference is also as expected but it was very slow.
Then I realized I should give batch size 1 in my cfg file.
I changed batch size to 1 in my yolov4-tiny.cfg and Onnx model is generated, Used trtexec to build an engine.
used this command:
sudo ./trtexec --onnx=yolov4-tiny.onnx --saveEngine=yolov4-tiny.rt --fp16 --verbose
But when I run inference on some test data, I get correct classes, probs but boxes are not correct.
They are way too small and placed at the top of the image everytime.
What could be the reason for this ?
Should I change something here ->(in the output calculation) postprocess when I change the batch size to 1.
You can refer below link for all the supported operators list, in case any operator is not supported you need to create a custom plugin to support that operation
Also, request you to share your model and script if not shared already so that we can help you better.
Meanwhile, for some common errors and queries please refer to below link:
