To run yolo5s on my jetson nano, When I run by the command:
deepstream-app -c deepstream_app_config.txt
I get result around 8.5 FPS
and when I try using binding in python I get very slow result I can’t understand why? of course I need to mention that I new with deepstream I learn this only this week and using python binding can very help me to my goals.
I add to short videos of the result I would be happy to any help thank you :)
Hi first thank you to reply, I didn’t understand how you see in the screenshot 8 fps maybe I miss something but in general, what I mean is that you can see that the video run more slowly on the screen when I use python binding, In addition, you can see in the video that I get in the terminal the message There may be timestamping problem or this computer is to slow. and pay attention to NVDEC there are different between videos.
from the second video, I can see the video is stuck, where did you get that deeptream-yolo.py? it is custom code? you can set sync=0 in [sink] configuration.
and when I run yolo-Tracker.py I get the same slow result absolutely I do something wrong maybe configuration or something like that I just need to figure out.
I am really sure that I do something wrong with the configuration and because of this I get a slow result I will be very happy if you can help me to figure it out.
** ERROR: <gst_nvinfer_parse_config_file:1303>: failed
here is an error, parsing configuration file failed, can you narrow down this issue? you can compare it with original file.
When I run yolo with the configuration: config_infer_primary_yoloV5.txt (629 Bytes)
I don’t get parsing problem but my yolo run very slow like you see in the short video.
note that the parser error is: Could not find group property
There is some log or something that I can add to the original code to understand where is the parsing problem?
I control my jetson nano with remote ssh using pycharm and try to debug the problem but still can’t figure out what happened I came to the line code pgie.set_property('config-file-path', "deepstream_app_config_yoloV5_check.txt")
and just get the error parsing it’s difficult to understand where it falls and I try to compare it to another deepstream-config.txt it seems to me ok.
