Hello.
I was trying to use LI-AR0820-GMSL2-XAVIER gmsl2 camera on YOLO V5.
I installed the driver correctly and I can see the output:
zacharyzhang@tegra-ubuntu:~$ ls /dev/video0
/dev/video0
and:
zacharyzhang@tegra-ubuntu:~$ v4l2-ctl --list-devices
vi-output, ar0820 30-0010 (platform:15c10000.vi:0):
/dev/video0
vi-output, ar0820 31-0010 (platform:15c10000.vi:2):
/dev/video1
vi-output, ar0820 32-0010 (platform:15c10000.vi:4):
/dev/video2
vi-output, ar0820 33-0010 (platform:15c10000.vi:5):
/dev/video3
However, when I try to run yolov5, it gives me the error:
zacharyzhang@tegra-ubuntu:~/apexy-project$ python3 detect.py --source 0
detect: weights=best.pt, source=0, data=data/dagm.yaml, imgsz=[640, 640], conf_thres=0.25, iou_thres=0.45, max_det=1000, device=0, view_img=False, save_txt=False, save_conf=False, save_crop=False, nosave=False, classes=None, agnostic_nms=False, augment=False, visualize=False, update=False, project=runs/detect, name=exp, exist_ok=False, line_thickness=3, hide_labels=False, hide_conf=False, half=False, dnn=False
YOLOv5 🚀 5e23b2b torch 1.10.0 CUDA:0 (Xavier, 31921MiB)
Fusing layers...
Model Summary: 213 layers, 1772695 parameters, 0 gradients, 4.2 GFLOPs
[ WARN:0@15.570] global /io/opencv/modules/videoio/src/cap_v4l.cpp (1910) getProperty VIDEOIO(V4L2:/dev/video0): Unable to get camera FPS
[ WARN:0@28.849] global /io/opencv/modules/videoio/src/cap_v4l.cpp (1000) tryIoctl VIDEOIO(V4L2:/dev/video0): select() timeout.
1/1: 0... Success (inf frames 3840x2160 at 99.00 FPS)
File "detect.py", line 257, in <module>
main(opt)
File "detect.py", line 252, in main
run(**vars(opt))
File "/home/zacharyzhang/.local/lib/python3.6/site-packages/torch/autograd/grad_mode.py", line 28, in decorate_context
return func(*args, **kwargs)
File "detect.py", line 105, in run
dataset = LoadStreams(source, img_size=imgsz, stride=stride, auto=pt)
File "/home/zacharyzhang/apexy-project/utils/datasets.py", line 323, in __init__
s = np.stack([letterbox(x, self.img_size, stride=self.stride, auto=self.auto)[0].shape for x in self.imgs])
File "/home/zacharyzhang/apexy-project/utils/datasets.py", line 323, in <listcomp>
File "/home/zacharyzhang/apexy-project/utils/augmentations.py", line 93, in letterbox
shape = im.shape[:2] # current shape [height, width]
AttributeError: 'NoneType' object has no attribute 'shape'
Any help would be really appreciated!
