In deepStream-imagedata-multistream, I use his original example, which is running properly and saved in the Frames directory. Then I changed the dstest_imagedata_config.txt file to replace the configuration with my Yolov model, and my model was converted by the following steps :pt – WTS – engine.
I then executed the following command: sudo LD_PRELOAD=./libmyplugins.so python3 deepStream_imagedata-multistream.py < file://> Frames. Although the program runs successfully, there is no file saved in the frames directory, and there is no warning in the program. What is the reason? How can I solve it?
• DeepStream Version
• TensorRT Version
