• OS: Ubuntu 24.04
• Hardware Platform (Jetson / GPU): GPU
• DeepStream Version: 8.0
• TensorRT Version: 10.9.0.34-1+cuda12.8 (both libnvinfer and tensorrt, as mentioned in Deepstream documentation here)
• NVIDIA GPU Driver Version (valid for GPU only): 570
If I used the onnx files given by nvidia here for yolov8 and yolov11 along with config file from that repo, I am getting correct detections (example image at very bottom), however, if I downloaded yolov8 or yolo11 from ultralytics and export the .pt model to .onnx myself and created engine file, I am getting wrong infer results (example below) and also, all the bboxes are at the top left of the image (please see image below).
Here is how I got the onnx file and then the engine file:
from ultralytics import YOLO
yolo = YOLO("yolov11s.pt") # I have downloaded yolov8s.pt from here https://docs.ultralytics.com/models/yolov8/#performance-metrics
yolo.export(format="onnx") # This created yolov11s.onnx in the same folder
Then, I created engine file using the command:
/usr/src/tensorrt/bin/trtexec --onnx=yolov8s.onnx --fp16 --saveEngine=yolov8s.onnx_b1_gpu0_fp16.engine
Then, I used this engine file in my deepstream python app which runs deepstream using pyds. I used this config_infer_primary_yoloV8.txt which I got from this nvidia-ai-iot deepstream_tools repo. I built libnvdsinfer_custom_impl_Yolo.so on the same machine using the instructions in that repo, and used it. Only changes I made in the config file before using in my deepstream app are the following:
onnx-file: absolute path to the onnx fileint8-calib-file: Commented this out as I was trying fp16 enginebatch-size: 1model-engine-file: absolute path to the engine file saved by the trtexec command abovelabelfile-path: absolute path to the labels file (downloaded and used this from the same repo)network-mode: 2custom-lib-path: absolute path to the built file
Notes: All other values in the config file are not changed. I have copied all these 4 files (onnx, engine, labels, libnvdsinfer_custom_impl_Yolo) to the same folder as the config file, and gave absolute paths in the config file.
The following are the outputs that I see. Please notice the label names, and also that they are all at the top left.
Counts: Counter({'scissors': 2, 'vase': 1, 'train': 1})
I came across this old forum post: https://forums.developer.nvidia.com/t/get-wrong-infer-results-while-testing-yolov4-on-deepstream-5-0/125526
From the solution of the above post, I have checked for compatibility of torch and tensorrt versions using this tensorrt documentation, I have found that they are compatible.
| Required versions | My Versions in conda venv which is used for export from pt to onnx |
| PyTorch >= 2.0 | torch==2.9.1 |
| ONNX=1.16.0 | onnx==1.16.0 (I also tested with 1.19.0 before downgrading to 1.16.0) |
The following shows an image of correct detections with same config file with nvidia’s onnx files taken from this nvidia-ai-iot deepstream_tools repo (as mentioned in the beginning of this post):
Can you please help with why my pt → onnx → engine is not giving correct results, but, nvidia’s pre-trained and exported onnx → engine is giving correct results with same config file and same lib libnvdsinfer_custom_impl_Yolo.so?
