YoloV8 false negatives
• Hardware Platform (Jetson / GPU) NVIDIA GeForce RTX 3050 Ti Mobile GPU
• DeepStream Version 7.0
• TensorRT Version
• Issue Type( questions, new requirements, bugs) Question
I’m running YoloV8 and trying to increase my detection rate, even at the cost of false negatives. My config is
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-color-format=0
onnx-file=../models/object_detection/yolov8m.onnx
model-engine-file=../models/object_detection/yolov8m_b1_gpu0_fp32.engine
labelfile-path=../models/object_detection/labels.txt
batch-size=1
network-mode=0
num-detected-classes=80
interval=0
gie-unique-id=1
process-mode=1
network-type=0
cluster-mode=2
maintain-aspect-ratio=1
symmetric-padding=1
parse-bbox-func-name=NvDsInferParseYolo
custom-lib-path=../custom_libs/nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so
engine-create-func-name=NvDsInferYoloCudaEngineGet
filter-out-class-ids=5;9;10;11;12;13;14;15;16;17;18;19;20;21;22;23;24;25;26;27;28;29;30;31;32;33;34;35;36;37;38;39;40;41;42;43;44;45;46;47;48;49;50;51;52;53;54;55;56;57;58;59;60;61;62;63;64;65;66;67;68;69;70;71;72;73;74;75;76;77;78;79;80
[class-attrs-all]
nms-iou-threshold=0.45
pre-cluster-threshold=0.10
post-cluster-threshold=0.10
topk=300
Lowering the pre-cluster-threshold and post-cluster-threshold does not increase the detection rate, however increasing them does lower the detection rate above around 0.6
Expected behavior: Lowering the thresholds increases the detection rate, including false positives
Actual behavior: Lowering the thresholds below 0.3 randomly increases or decreases the number of detections by about 1%.
Is this the intended functionality?
it is related to cluster. AYK, cluster algorithm will combine some detection bboxes.
  1. can you try cluster-mode=4? which means " No clustering", then all the bounding box rectangle proposals are returned as it is.
  2. if using cluster-mode=2( NMS), you can set nms-iou-threshold a big value, then most bboxes will be saved.
