I had the same problem with the latest ultralytics version. I found a clue to solve the problem. We can give image input with dataloaders.py in yolov9. Here, with some work with videocapture, it provides synchronization between the camera image input and yolo’s fps. I wonder if this is not available in ultralystics? The dataloaders.py code I used for yolov9 is as follows.
def gstreamer_pipeline(self,
sensor_id=0,
capture_width=1600 ,
capture_height=900 ,
display_width=1600 ,
display_height=900 ,
framerate=30,
flip_method=2,
return (
"nvarguscamerasrc sensor-id=%d ! "
"video/x-raw(memory:NVMM), width=(int)%d, height=(int)%d, framerate=(fraction)%d/1 ! "
"nvvidconv flip-method=%d ! "
"video/x-raw, width=(int)%d, height=(int)%d, format=(string)BGRx ! "
"videoconvert ! "
“video/x-raw, format=(string)BGR ! appsink”
sensor_id,
capture_width,
capture_height,
framerate,
flip_method,
display_width,
display_height,
YOLOv5 streamloader, i.e. python detect.py --source 'rtsp://example.com/media.mp4' # RTSP, RTMP, HTTP streams
def init(self, sources=‘streams.txt’, img_size=640, stride=32, auto=True, transforms=None, vid_stride=1):
torch.backends.cudnn.benchmark = True # faster for fixed-size inference
self.mode = ‘stream’
self.img_size = img_size
self.stride = stride
self.vid_stride = vid_stride # video frame-rate stride
sources = Path(sources).read_text().rsplit() if os.path.isfile(sources) else [sources]
n = len(sources)
self.sources = [clean_str(x) for x in sources] # clean source names for later
self.imgs, self.fps, self.frames, self.threads = [None] * n, [0] * n, [0] * n, [None] * n
for i, s in enumerate(sources): # index, source
# Start thread to read frames from video stream
st = f’{i + 1}/{n}: {s}… ’
if urlparse(s).hostname in (‘www.youtube.com’, ‘youtube.com’, ‘youtu.be’): # if source is YouTube video
# YouTube format i.e. ‘https://www.youtube.com/watch?v=Zgi9g1ksQHc’ or ‘https://youtu.be/Zgi9g1ksQHc’
check_requirements((‘pafy’, ‘youtube_dl==2020.12.2’))
import pafy
s = pafy.new(s).getbest(preftype=“mp4”).url # YouTube URL
s = eval(s) if s.isnumeric() else s # i.e. s = ‘0’ local webcam
if s == 0:
assert not is_colab(), ‘–source 0 webcam unsupported on Colab. Rerun command in a local environment.’
assert not is_kaggle(), ‘–source 0 webcam unsupported on Kaggle. Rerun command in a local environment.’
#cap = cv2.VideoCapture(s)
cap = cv2.VideoCapture(self.gstreamer_pipeline(),cv2.CAP_GSTREAMER)
assert cap.isOpened(), f’{st}Failed to open {s}’
w = int(cap.get(cv2.CAP_PROP_FRAME_WIDTH))
h = int(cap.get(cv2.CAP_PROP_FRAME_HEIGHT))
fps = cap.get(cv2.CAP_PROP_FPS) # warning: may return 0 or nan
self.frames[i] = max(int(cap.get(cv2.CAP_PROP_FRAME_COUNT)), 0) or float(‘inf’) # infinite stream fallback
self.fps[i] = max((fps if math.isfinite(fps) else 0) % 100, 0) or 30 # 30 FPS fallback
_, self.imgs[i] = cap.read() # guarantee first frame
self.threads[i] = Thread(target=self.update, args=([i, cap, s]), daemon=True)
LOGGER.info(f"{st} Success ({self.frames[i]} frames {w}x{h} at {self.fps[i]:.2f} FPS)")
self.threads[i].start()
LOGGER.info('') # newline
# check for common shapes
s = np.stack([letterbox(x, img_size, stride=stride, auto=auto)[0].shape for x in self.imgs])
self.rect = np.unique(s, axis=0).shape[0] == 1 # rect inference if all shapes equal
self.auto = auto and self.rect
self.transforms = transforms # optional
if not self.rect:
LOGGER.warning('WARNING ⚠️ Stream shapes differ. For optimal performance supply similarly-shaped streams.')
def update(self, i, cap, stream):
# Read stream i
frames in daemon thread
n, f = 0, self.frames[i] # frame number, frame array
while cap.isOpened() and n < f:
n += 1
cap.grab() # .read() = .grab() followed by .retrieve()
if n % self.vid_stride == 0:
success, im = cap.retrieve()
if success:
self.imgs[i] = im
else:
LOGGER.warning(‘WARNING ⚠️ Video stream unresponsive, please check your IP camera connection.’)
self.imgs[i] = np.zeros_like(self.imgs[i])
cap.open(stream) # re-open stream if signal was lost
time.sleep(0.0) # wait time
def iter(self):
self.count = -1
return self
def next(self):
self.count += 1
if not all(x.is_alive() for x in self.threads) or cv2.waitKey(1) == ord(‘q’): # q to quit
cv2.destroyAllWindows()
raise StopIteration
im0 = self.imgs.copy()
if self.transforms:
im = np.stack([self.transforms(x) for x in im0]) # transforms
else:
im = np.stack([letterbox(x, self.img_size, stride=self.stride, auto=self.auto)[0] for x in im0]) # resize
im = im[..., ::-1].transpose((0, 3, 1, 2)) # BGR to RGB, BHWC to BCHW
im = np.ascontiguousarray(im) # contiguous
return self.sources, im, im0, None, ''
def len(self):
return len(self.sources) # 1E12 frames = 32 streams at 30 FPS for 30 years
