I am trying to run YOLOv8 on a Jetson Nano with Cuda acceleration.
And I have to switch from python3.6 to python3.8.
And this means I can not use my prebuilt torch library that comes with Cuda.
I was wondering has anyone made an effort to build PyTorch on jetson nano with python3.8?
You can find the instructions for building the PyTorch library in the below topic:
> Instructions
>> Build from Source
Thanks for the reply.
Actually, I am following the “Build from Source” instructions to build torch 1.10.1 on my Jetson Nano. I have also increased my Swap area to 4GB, and work in a virtualenv with python 3.8 (to be used with YOLOv8).
But now, the error I face is that while “Building CXX object caffe2/CMakeFiles/torch_cpu.dir/__/torch/csrc/autograd/generated/VariableType_1.cpp.o”
it shows a “c++: internal compiler error: Killed (program cc1plus)” and it does not progress anymore.
Any thoughts on this would be really appreciated.
Maybe trying other versions of pytorch?
Can it be a memory problem? Or something else?
Yes, killed is usually related to the memory issue.
Could you increase the swap memory size and try it again?
