Young's modulus for deformable object
Hello, may I set young’s modulus for the deformable object? I want to make a cable and the current deformable object is like jelly and too soft for me
You need to create a deformable material, which has the Young’s, and then assign it to the deformable body object. See https://docs.omniverse.nvidia.com/prod_extensions/prod_extensions/ext_physics/deformable-bodies.html
Thanks for your reply! Can I also set Young’s in PhysX4.1 or Flex? by creating a deformable material?
PhysX 4.1 doesn’t feature deformables. Flex features shaped matched deformables, which are controllable via stiffness IIRC.
