Your topic is similar to… Request to enable Public API Endpoints permission for my personal organization NGC Account cuda Request to enable “Public AP
Hello NVIDIA Support Team,
I am using NVIDIA NIM with a Personal Organization for personal development, learning, and testing.
My NVIDIA API key is active, and I can successfully access the model list:
GET https://integrate.api.nvidia.com/v1/models
This request returns HTTP 200.
The available model list includes:
  • moonshotai/kimi-k2.6
  • moonshotai/kimi-k3
  • openai/gpt-oss-20b
However, inference requests to the following endpoint consistently time out:
POST https://integrate.api.nvidia.com/v1/chat/completions
I tested this directly from Python using the requests library, with both stream=false and stream=true, and with very small prompts and short token limits. The requests do not return an HTTP response and eventually fail with a ReadTimeout.
Network connectivity to integrate.api.nvidia.com is working successfully.
My API key settings page does not show a “Public API Endpoints” permission or any option to enable it.
Could you please check whether the “Public API Endpoints” entitlement is enabled for my Personal Organization and enable it if required, or advise me what is needed to access the hosted inference endpoints?
Use case: personal development, learning, and testing.
I will comply with NVIDIA API terms and rate limits.
Thank you.
Well, did you/your org verify the mobile phone number?
Yes, of course
