• GeForce GTX 1660 Ti Mobile
• DeepStream 6.1
• Ubuntu 20.04
• GStreamer 1.16.2
• NVIDIA driver 510.47.03
• CUDA 11.6 Update 1
Can I get a youtube stream as input stream for deepstream? Are there any examples for python?
• DeepStream 6.1
• Ubuntu 20.04
• GStreamer 1.16.2
There is no youtube related example in deepstream.
Can you get the URL of the stream? Which codec does it use?
I want to parse this link
I can watch in terminal with gst by:
gst-launch-1.0 souphttpsrc is-live=true location="$(yt-dlp --get-url https://www.youtube.com/watch?v=RoVIM4BYbZ8)" ! decodebin ! videoconvert ! nvvideoconvert ! 'video/x-raw', format=NV12 ! nveglglessink
But when I add it like source, I have an error.
Code:
def create_source_bin(self, index, uri):
bin_name = "source-bin-%02d" % index
print(bin_name)
nbin = Gst.Bin.new(bin_name)
if not nbin:
sys.stderr.write(" Unable to create source bin \n")
uri_decode_bin = Gst.ElementFactory.make("souphttpsrc", "souphttpsrc_0")
if not uri_decode_bin:
sys.stderr.write(" Unable to create uri decode bin \n")
loc_str = '$(yt-dlp --get-url https://www.youtube.com/watch?v=RoVIM4BYbZ8)'
uri_decode_bin.set_property('location', loc_str)
Gst.Bin.add(nbin, uri_decode_bin)
bin_pad = nbin.add_pad(Gst.GhostPad.new_no_target("src", Gst.PadDirection.SRC))
if not bin_pad:
sys.stderr.write(" Failed to add ghost pad in source bin \n")
return None
return nbin
Error:
(python3:33662): GStreamer-CRITICAL **: 16:36:58.899: gst_query_set_uri: assertion 'gst_uri_is_valid (uri)' failed
Error: gst-resource-error-quark: Error parsing URL. (5): gstsouphttpsrc.c(1463): gst_soup_http_src_build_message (): /GstPipeline:pipeline0/GstBin:source-bin-00/GstSoupHTTPSrc:souphttpsrc_0:
URL: $(yt-dlp --get-url https://www.youtube.com/watch?v=RoVIM4BYbZ8)
Exiting app
I can get url with bash:
echo $(yt-dlp --get-url https://www.youtube.com/watch?v=RoVIM4BYbZ8)
https://manifest.googlevideo.com/api/manifest/hls_playlist/expire/1672256307/ei/00asY4PxKMfR7gSf5pbYAQ/ip/85.234.35.135/id/RoVIM4BYbZ8.2/itag/96/source/yt_live_broadcast/requiressl/yes/ratebypass/yes/live/1/sgoap/gir%3Dyes%3Bitag%3D140/sgovp/gir%3Dyes%3Bitag%3D137/hls_chunk_host/rr8---sn-jvhnu5g-045e.googlevideo.com/playlist_duration/30/manifest_duration/30/spc/zIddbI3dgrlW-FqeIFYG6dPJygHQ0uo/vprv/1/playlist_type/DVR/initcwndbps/1783750/mh/1c/mm/44/mn/sn-jvhnu5g-045e/ms/lva/mv/m/mvi/8/pl/24/dover/11/pacing/0/keepalive/yes/fexp/24001373,24007246/mt/1672234364/sparams/expire,ei,ip,id,itag,source,requiressl,ratebypass,live,sgoap,sgovp,playlist_duration,manifest_duration,spc,vprv,playlist_type/sig/AOq0QJ8wRAIga0CxE7ffvCH6quvPcfbdCtmoBcnOF7Ooqa1llUcYCxQCIB6V4859D43XiO_fbFuqzF5lX9cYwddS3jOY1zKNnknY/lsparams/hls_chunk_host,initcwndbps,mh,mm,mn,ms,mv,mvi,pl/lsig/AG3C_xAwRAIgC5vX6MdaPbDIYL3NutWIiUpov4Qb9a-udG3M8gkhLycCICOjwYuqp22I_JXdwFPHLzTyB6Nlm5qL1dqe2puEkTdc/playlist/index.m3u8
When I paste this url to python function, that discribed higher, I have this:
Error: gst-stream-error-quark: Internal data stream error. (1): gstbasesrc.c(3072): gst_base_src_loop (): /GstPipeline:pipeline0/GstBin:source-bin-00/GstSoupHTTPSrc:souphttpsrc_0:
streaming stopped, reason not-linked (-1)
Exiting app
You may try instead:
import subprocess
loc_str = subprocess.check_output(['/usr/bin/yt-dlp', '--get-url', 'https://www.youtube.com/watch?v=RoVIM4BYbZ8'])
This is a good way to get the URL. But I have the same error.
My function:
print(bin_name)
if not nbin:
['yt-dlp', '--get-url', 'https://www.youtube.com/watch?v=RoVIM4BYbZ8'])
uri_decode_bin.set_property('location', loc_str.decode("utf-8"))
if not bin_pad:
return None
return nbin
Error:
Exiting app
If i don’t decode:
My error:
(python3:136672): GStreamer-CRITICAL **: 09:59:48.879: gst_query_set_uri: assertion 'gst_uri_is_valid (uri)' failed
URL: b'https://manifest.googlevideo.com/api/manifest/hls_playlist/expire/1672318786/ei/4jqtY4WsA4rO7gSs0r3ACw/ip/85.234.35.135/id/RoVIM4BYbZ8.2/itag/96/source/yt_live_broadcast/requiressl/yes/ratebypass/yes/live/1/sgoap/gir%3Dyes%3Bitag%3D140/sgovp/gir%3Dyes%3Bitag%3D137/hls_chunk_host/rr2---sn-gvnuxaxjvh-2x1e.googlevideo.com/playlist_duration/30/manifest_duration/30/spc/zIddbFS7gk57NK-UWiPJED93DCZXcz8/vprv/1/playlist_type/DVR/initcwndbps/1855000/mh/1c/mip/85.237.57.85/mm/44/mn/sn-gvnuxaxjvh-2x1e/ms/lva/mv/m/mvi/2/pl/24/dover/11/pacing/0/keepalive/yes/fexp/24001373,24007246/mt/1672296752/sparams/expire,ei,ip,id,itag,source,requiressl,ratebypass,live,sgoap,sgovp,playlist_duration,manifest_duration,spc,vprv,playlist_type/sig/AOq0QJ8wRgIhANEACsphTt7TQwUFYNt6L36mFzTiVjcnjsDMigVVKTpJAiEAnT7_rPS5iOSEDgN2bnbkbC-NOXKARhYADdBrbMvMHtE%3D/lsparams/hls_chunk_host,initcwndbps,mh,mip,mm,mn,ms,mv,mvi,pl/lsig/AG3C_xAwRAIgWv-R5RHQiCFD8Eo9BwuBUax_Cz1tIiBi9Wk_ZWHUhVICIBZgEbUsaznXylg636rmK6bw89VQL_Hc79QVjpm3rg5N/playlist/index.m3u8\n'
Exiting app
If i am using
loc_str = subprocess.check_output(['youtube-dl', '--get-url', 'https://www.youtube.com/watch?v=RoVIM4BYbZ8'])
Please google the usage of souphttpsrc by yourself. souphttpsrc (gstreamer.freedesktop.org)
It is not a DeepStream issue.
Try using uridecodebin instead of soupĥttpsrc + decodebin:
uri_decode_bin = Gst.ElementFactory.make("uridecodebin", "uridecodebin_0")
uri_decode_bin.set_property('uri', loc_str.decode("utf-8"))
