YUV2RGB color space conversion coefficients in DeepStream SDK 6.3
• Hardware Platform (Jetson / GPU) Orin NX
• DeepStream Version 6.3
• TensorRT Version 8.5.2.2
• NVIDIA GPU Driver Version (valid for GPU only) Orin NX
• Issue Type( questions, new requirements, bugs) Questions
I would like to know the conversion coefficients of YUV2RGB in DeepStream SDK 6.3.
Please provide this iunformation.
Thanks,
Bruno
TV range or full range ? Which one is used for YUV2RGB conversion on deepstream?
Or does it depend on any condition?
I am looking forward to any information.
Which part are you asking?
Several formats are supported. NVIDIA DeepStream SDK API Reference: NvBufSurface Types and Functions | NVIDIA Docs
We got video stream from USB(UVC) with MJPEG format.
From pipeline chart, we can see NV12 format convert to RGBA.
W’d like to know the coefficients of conversion.
Which mjpeg decoder are you using?
jpg_dec = gst_element_factory_make (“jpegdec”, “jpeg-decoder”);
This is not DeepStream element. It is open source decoder gstreamer/subprojects/gst-plugins-good/ext/jpeg/gstjpegdec.c at 1.20 · GStreamer/gstreamer (github.com). You need to check the output format of the jpegdec decoder to find out whether the output format is already RGB or not.
Thanks and whicj element should we use?
You can use nvv4l2decoder with DeepStream. Gst-nvvideo4linux2 — DeepStream documentation 6.4 documentation
We are asking how NV12 format convert to RGBA? Is the coefficients used for full range or tv range?
Seems not related to JPEG decoder.
For video decoded from h264 and h265, the colorspace will be impacted by the information from the decoder.
For JPEG, the coeffs are tv range
