Z-high tolerance for Orin NX GPU Die?
Dear:
we only found the MAX 4.08 in the DS, and we want to know the Z high tolerance for GPU Die,
need this for our thermal design, thanks
The Z-height specification for all components, including the GPU die, is provided as a MAX value only by default. There is no separate tolerance or MIN value published.
For your thermal design, please use the MAX value (4.08mm) as the reference. This is the standard practice because the thermal solution (TIM thickness, thermal pad, heatsink gap) must accommodate the worst-case (tallest) component height to ensure proper contact pressure and thermal performance across all production units. Designing to a nominal or minimum value would risk insufficient contact or excessive gap on units at the upper end of the manufacturing distribution.
