This is some notes about building z3 with HPC SDK 20.7:
- in src/muz/base/dl_rule_set.h, “void restrict(const item_set & allowed);” has restrict compiled as a keyword, with the build as such failing, renaming the name resolves the issue.
- when building src/muz/base/dl_context.cpp:
`Block containing LandingPadInst must be jumped to only by the unwind edge of an invoke.
%283 = landingpad %astruct.dt64
cleanup
LLVM ERROR: Broken module found, compilation aborted!`
… the compiler breaks down, as such I built just that file with g++…
… but then, when running the testsuite (make test and then trying to run the testsuite):
1 3 2
*ASSERTION VIOLATION
File: ../src/test/total_order.cpp
Line: 122
Failed to verify: to.lt(v[k], v[k+1])
Z3 4.8.10.0
Please file an issue with this message and more detail about how you encountered it at https://github.com/Z3Prover/z3/issues/new
Those tests were done on an AArch64 machine. (NVIDIA Carmel processor)
Thank you,
(Building z3 with NVIDIA's compilers · Issue #4694 · Z3Prover/z3 · GitHub)
