The current Isaac ROS Nvblox ZED camera example appears to rely on an older ZED depth configuration, while recent versions of the ZED SDK / ZED ROS 2 Wrapper provide newer depth modes such as NEURAL and NEURAL_LIGHT.
Since Nvblox consumes the depth image generated by the ZED ROS 2 Wrapper, the ZED depth_mode can have a significant impact on the quality of the depth input and consequently on Nvblox reconstruction and obstacle detection.
Current behavior
When using the ZED camera example with Isaac ROS Nvblox, the ZED depth configuration appears to be based on an older configuration.
For example, the configuration may still use:
depth:
depth_mode: ULTRA
while newer versions of the ZED SDK / ROS 2 Wrapper support newer modes such as:
depth:
depth_mode: NEURAL
and:
depth:
depth_mode: NEURAL_LIGHT
This makes it unclear whether the current Nvblox ZED example is intentionally using the older depth mode for compatibility/performance reasons, or whether the example configuration has not yet been updated.
Why this matters
Nvblox does not directly calculate the ZED stereo depth. The data flow is approximately:
ZED X
v
ZED SDK
| depth_mode
v
ZED ROS 2 Wrapper
| /zed/zed_node/depth/depth_registered
v
Isaac ROS Nvblox
v
TSDF / Occupancy / Costmap
Therefore, the ZED depth_mode is an important part of the Nvblox ZED integration.
In particular, different depth modes can produce different:
- depth accuracy
- depth noise
- missing-depth regions
- edge quality
- obstacle reconstruction quality
- GPU/CPU utilization
- processing latency
These differences can directly affect Nvblox reconstruction and Nav2 obstacle detection.
Question
Could the maintainers clarify whether the ZED Nvblox example is intentionally using the older depth mode?
If not, could the ZED example configuration and documentation be updated to reflect the currently supported ZED depth modes?
For example, it would be useful if the example explicitly documented:
- Which ZED depth mode is recommended for Nvblox.
- Which depth modes are supported with ZED / ZED X.
- Why a particular depth mode is selected.
- The expected performance/quality trade-offs between
NEURAL,NEURAL_LIGHT, and other supported modes. - Whether the recommended depth mode differs between static and dynamic Nvblox modes.
Additional observation
This is particularly relevant for ZED X users. In our testing, changing the ZED depth configuration can noticeably affect the resulting Nvblox reconstruction, especially when using dynamic reconstruction.
It would therefore be helpful to have an officially recommended ZED depth configuration for Nvblox rather than relying on the default configuration of the ZED ROS 2 Wrapper.
References
- Isaac ROS Nvblox repository: GitHub - NVIDIA-ISAAC-ROS/isaac_ros_nvblox: NVIDIA-accelerated 3D scene reconstruction and Nav2 local costmap provider using nvblox · GitHub
- ZED ROS 2 Wrapper: GitHub - stereolabs/zed-ros2-wrapper: ROS 2 wrapper for the ZED SDK · GitHub
Thank you.
